January 12th, 2006, 03:52 PM #1Member
- Feb 2003
- 46
Will a faster rpm hd kick my p3 in the
my current hd is 5400 rpm 2mb cashe, its an i810 chipset board that runs at 100 mhz, I upraded the cely to a pentium III. is it worth spending any money on a faster hd for this machine? No games just websurfing, some autocad, and it might run a CNC machine someday.
January 12th, 2006, 04:00 PM #2Member
- Jun 2004
- 74
Perhaps. A 7200rpm drive with a bigger cache may get you a bit better performance, especially with load times.
Look up some benchmarks and graphs on hard drive performance, benchmark your hdd's performance and compare to any ideal hard drive you want. It should tell you if there would be a performance difference.
January 12th, 2006, 08:31 PM #3
If it's an old drive, then any new drive will probably give you a bit more pep -- even a newer model 5400PRM drive.
Whether it's worth it, is a different question. If the major bottleneck in your system isn't storage, then upgrading storage isn't going solve that problem.
4200 RPM or 7200 RPM hard drive
By doctorantonio in forum Storage RelatedReplies: 8Last Post: May 23rd, 2005, 04:13 PM -
15000 RPM & 10000 RPM Harddisk
By fakhry in forum Storage RelatedReplies: 17Last Post: June 25th, 2003, 02:33 PM -
Whats the difference between *src.rpm and *i386.rpm?
By d1sc g0lf3r in forum Applications and Operating SystemsReplies: 5Last Post: January 1st, 2003, 07:36 PM -
I could kick myself...
By cracked in forum General Tech DiscussionReplies: 17Last Post: December 30th, 2002, 07:21 PM -
is there a big difference in performance between a 5400 rpm hd and a 7200 rpm? -- NT
By gorath in forum Storage RelatedReplies: 3Last Post: June 8th, 2002, 07:21 PM
I havent turned on my 360 in months, Ive went back to pc gaming (mainly because bf3 runs like crap on the console)
Xbox One Announced
