RAID 0 configuration help  | | |
August 15th, 2006, 07:39 AM
| | Super Duper Member
I have two identical maxtor 7200rpm 80Gb drives and currently have a RAID ) setup with them. however i have no idea how to instal windows split on the two drives. currently i have it installed on a partition on one disk and the rest in the RAID 0 config. does anyone kno how i can do this? |
August 15th, 2006, 09:15 AM
| | Super Duper Member
well actually what i did was have two drives there and then i installed windows on a partition on one hard disk. and have the rest of the disk taht does not have the system files on a RAID 0 thingy do you mean after that install windows again and instal it on one of the stripped partitions? are the drives supposed to look as one from the beginning? cuz when i installed it both drives were freshly formatted. is that wrong? |
August 15th, 2006, 10:52 AM
| | Super Duper Member
no actually in the installing thingy the two drives appeared as two. so i made a partition for windows. 30gb and so i couldnt RAID the 30gb on the other disk without windows. yea so its like that. how do you instal window3as on both drives splitr? |
August 15th, 2006, 11:12 AM
| | Super Duper Member
yea i tried that buit nothing happens when i press F6. yea and what do you mean by create the raid?
August 15th, 2006, 12:04 PM
| | Millwright
F6 is XP drivers, the RAID setup has nothing to do with windows.
When you first turn on your computer, after the POST screen ( page where you press DEL to enter setup). The next screen is the RAID screen, were you press F5 or somthing like that. It will say what to press to enter, on the screen.
August 15th, 2006, 12:14 PM
| | Millwright
| Quote: |
Originally Posted by pullmyfoot yea i tried that buit nothing happens when i press F6. yea and what do you mean by create the raid? | Oh, and by the way, after you set up your RAID, and start XP setup and press F6 for third party drivers, nothing will happen untill later in the installatoin.
You shouldn't need F6 for the IDE drives.
August 15th, 2006, 11:53 PM
You can't get there from here
August 16th, 2006, 08:31 AM
| | Super Duper Member
August 16th, 2006, 02:03 PM
What's the best size to set the stripes to? |
August 20th, 2006, 11:55 AM
Helloo, is anybody out there? |
