Results 1 to 12 of 12
    Oct 2002
    119
    How do I find the volume label on a new seagate external hard drive?
    Its fat32 and I already have it half filled before I found out that it wont take a file larger than 4gb. I am going to convert to ntfs but have no idea where to find the volume label of the drive (as the convert command asks)
    Any help is appreciated.
    Healdsburg, CA
    13,309
    Well, there's two ways to tell. In My Computer, right click the drive and select Properties. In the General tab, the volume label is the name in the top box. Or you can go to Control Panel > Administrative Tools > Computer Management > Disk Management and in the top pane it will list the drives by Volume.
    Vyx
    Vyx is offline
    Ultimate Member Vyx's Avatar
    May 2003
    Cheyenne, WY
    1,093
    AFAIK you shouldnt need to put in a volume label. The volume label is just a name you give to the drive.
    i.e. if you go to my computer and look at your drives you'll probably have something like (C:). A volume lable would be like "Label (C:)". So, if it requires you put one in to name the new drive, just put in whatever you want, if it wants the original label, look in my computer and put in whatever it says in the "Label" part.
    Gi | Yuu | Jin | Rei | Makoto | Meiyo | Chuugi
    Oct 2002
    119
    Ok, much thanks, it is converting now. I did not give the drive a volume label, seagate did that for me. It was SEA_DISC and would not convert unless I typed that in.
    Again, thanks!
    Nov 2008
    Smile found label
    on w98, went to disk properties, general tab, label in top box, delated label, typed in new label, went to fdisk, printed in new label in volume label, and the partion was deleted
    Mar 2007
    My own little world.
    11,764
    Hi, and firstly, WELCOME TO TECHIMO...
    The thread is getting on for two years old, and the OP was requesting info about converting from FAT32 to NTFS - rather than re-formatting the drive... The way you gave is also mentioned in the second post...
    If you re-format a drive you can indeed give it any name you feel like, so long as it doesn't have some specific characters in like back-slash ( \ ) or forward-slash ( / ) for example......
    Jan 2010
    Angry Don't work.
    Quote Originally Posted by Atomic Rooster View Post
    My computer keeps telling me I am entering the wrong volume. I typed FreeAgent (F.
    Mar 2007
    11,764
    Quote Originally Posted by Butkus76 View Post
    Hi, and WELCOME TO TECHIMO - from the Folding@Home Team [#111]...!
    If you open "My Computer" you should see the drive listed with a 'name' in addition to the drive letter.....this 'name' is what you need to enter into the "volume name" field....
    Millwright stroyal's Avatar
    Dec 2002
    New Hampshire
    8,059
    If there is no name next to the drive letter the volume label/ name is blank and you don't enter anything.
    You can right click it, and rename it anything you want.
    2 slow left clicks on the drive letter or volume name, will also let you rename it.
    The drive letter is not part of the volume label/name.
    Welcome to TechIMO!
    Hard Sayin Not Knowin
    Nov 2010
    hello,
    Thanks all for the helping
    I did the same as you said and it have been converted but it's still when I chick the file system it's the same FAT32 ?
    Nov 2011
    volume label
    I am assuming you are already in "command prompt".
    Make sure you are on the right drive Example C:
    When it asks you for a volume label type in vol after C: ( C: vol )
    The volume label and serial no. will show. Example C:\> vol
    volume in C is HP_PAVILION
    volume serial number is XXXX-XXXX
    HP_PAVILION is the label in this example
    Hope this is of help
    Mark
    Sep 2012
    volume lable
  1. Replies: 2
    Last Post: October 21st, 2005, 09:08 PM
  2. Seagate hard drive probs
    By jublee in forum Technical Support
    Last Post: July 4th, 2003, 06:37 PM
  3. volume label symbols
    By brunix in forum Storage Related
    Last Post: December 9th, 2002, 12:17 AM
