Join TechIMO for Free!
Thread Tools
Currently Active Users: 1528
Discussions: 186,731, Posts: 2,228,339, Members: 230,391
Old June 22nd, 2007, 03:39 PM   Digg it!   #1 (permalink)
Question
Please help! Have disk in drive E but computer says "Please insert disk into drive E"
Please help!!! I have a disk in my disk drive but everytime I try to run the disk the computer says "Please insert disk into drive E". The computer is able to eject the disk, but it just seems to not be able to read any disks inserted.
Then I tried to uninstall the drive and reboot. The computer reinstalls the drive but I still have the same problem. A few weeks ago I had downloaded and installed a game (iso file with no cd crack). I'm not sure if this had something to do with it but before I had installed the game the dvd drive worked perfectly, so I uninstalled the game but this also did not help.
I even tried unplugging the drives inside the computer and plugging them in again. NOTHING!!!
I have tried Temp clean-I.E cashe Clean. This does nothing. I have run a virus scan, I tried updating the driver but there is no better update, so then I tried to roll it back, NOTHING.
I tried deleting the upper and lower filters from the registry but my computer still does not read cd's, dvd's, or dvd movies!!! ( There was a lower filter but no upper filter).
This is what I keep trying to do to check if the computer will play a disk. I am able to eject the drive via start, my computer, dvd drive e (right click - eject). So I guess that the drive is reconized by the computer. When I put a disk into the dvd drive the computer does not automatically play.
So I go into
start
my computer
dvd drive e
A blank window opens with no data . Nothing is showing up as being on the disks.
Please Help!!!
This is very frustrating!!!
Thank you soooo much for your time.
Twigoria is offline   Reply With Quote
FREE instant scan
Old June 22nd, 2007, 11:30 PM     #2 (permalink)
well, that is exactly what happened 3 times with my friends optical drives.... all died(or at least thats what i assume).
They register in Device Manager and during the POST fine but try to use them....never works.
Although on my friends pc, if you were to put a disc in, the light would never shut off on one causing the screen to freeze until you took it out and his other drive what light up for a second or two then stop trying which of course isnt long enough to read anything. his other drive got tossed a long time ago.
That's my reply because i have a very similar problem posted here as well but relates to drives constantly failing.
I assume i am right in regards to it being dead because noone else has said otherwise in my topic so i would suggest buying you another drive.
But just for kicks, turn the pc off, unplug power and data cable going to drive, then plug both back in and turn on. If it still wont read discs....buy somethin new.
shizzzon is offline   Reply With Quote
Old June 24th, 2007, 09:48 PM     #3 (permalink)
How did you uninstall the drive? If you did not do it in Device Manager,then go into Device Manager and uninstall the drive. It's under dvd/cdrom devices. When you reboot, Windows will reinstall the drive. See if that fixes it. Let us know.
lenjack is offline   Reply With Quote
Thread Tools
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER drxfilek Storage Related 4 May 21st, 2006 09:19 PM
Disk boot failure, insert system disk and press enter--- modfreak33 Technical Support 3 May 18th, 2006 04:17 PM
Disk Boot Failure, Insert System Disk and Press Enter on New Build Scyxor Technical Support 8 January 6th, 2006 08:14 PM
Advice needed: "Defective Hard disk Drive Heads" rhflee Technical Support 2 January 30th, 2005 09:16 PM
"Insert disk in drive A" Theophylact Technical Support 25 July 27th, 2004 07:01 AM
Is It Just Me? (747)
Newegg WARS!!! (55)
Best graphics card for around $600 (8)
E5200 15.2GHZ?? (12)
Car Talk! (8693)
Folderchat: The Holiday thread (159)
New info on the Phenom II X4 (46)
Best Boot Drive Imaging Software (17)
Bought an AGP "HIS Radeon HD 3.. (21)
replacing tvs msp345 printer he.. (1)
LCD monitor sizes and wide scre.. (4)
Service Pack 3 (3)
Should I build my computer arou.. (0)
Computer won't start (15)
Best graphics card for around $.. (8)
Logitech Mx 3200? (1)
