flash drive broken - need to repair/recover
Currently Active Users: 1631
Discussions: 195,837, Posts: 2,327,874, Members: 241,369
Old September 5th, 2008, 06:43 PM   Digg it!   #1 (permalink)
so today the usb stem of my flashdrive broke, so now i can't connect it to my PC and i have alot of important files on there. So how would i repair this or get the data off the flashdrive
DeluzioNFX is offline   Reply With Quote
Old September 8th, 2008, 01:11 PM     #2 (permalink)
Caveat Emptor
Rootstonian's Avatar
By "stem" I assume you mean the part you put into the USB port?
You MAY be able to buy another same flashdrive and try to "engineer" one working one
I've never had one apart, so in your case, you may as well try what you can....good luck!
I use mine to xfer files or share pictures; never trust one as a storage device (i.e. make sure you have your data backed-up )
Rootstonian is online now   Reply With Quote
Old October 13th, 2008, 11:04 AM     #3 (permalink)
Wire wires to it
Since there are four connecting points on a usb device of any sort, what I would say is just use four peices of wire and solder them to each of the connectors on the actual flash drive and then sloder the other end of the wires to the corresponding terminals on the part that plugs into the computer. The only problem with this is that you can "pop" a device that is on flashdrives that keeps the power flow to the flash drive consistent. If in the proccess you didn't "pop" the device than you should be able to get the data off of it.
pattyboy7 is offline   Reply With Quote
Old October 22nd, 2008, 07:24 PM     #4 (permalink)
mya
snapped flashdrive
My brother stepped on my flashdrive and snapped it in two. Is there a way to fix it or a company I can send it to to be fixed?
Mya
mya is offline   Reply With Quote
Old October 24th, 2008, 12:58 PM     #5 (permalink)
Reality filters Fixer.
no1_vern's Avatar
It depends on where it was broken. Since most usb keys are a single pcb slab with a strip extending out into the USB connector, you can get someone who is handy to re-solder it together, and remove your data. While it can be reused, I would suggest that you do NOT trust it to anything valuable.
Here is a article with pics of a USB key and the repairs the writer did(his was a separate issue, the chip had come away from the PCB). To repair a broken USB flash drive - Tips & Tweaks
Sending it off to a company is feasible, but unless your willing to pay about $100 per key, it really isnt an option.
Feed a cat, GAIN a cat!
no1_vern is online now   Reply With Quote
Old March 4th, 2009, 08:27 AM     #6 (permalink)
Talking
Broken Flash drive
A friend of mine had one sticking out of a computer and someone kicked it by accident. The usb plug was bend to the side quite a bit and t did not work. I took the cover off and found 2 of the solder pads for the usb port were torn from the circuit board and one of the bent solder pieces on the USB plug was broken off. I thought about trying to solder a USB cable on to the connections. But when I scraped off the coating to make the solder connections for the cable I realized that the gap from the missing pieces was close enough if I bent the connectors on the USB port a little I could just bridge the gap with a little solder. I soldered a short piece of cable to replace the broken connector. It worked and I got the data off.
I am getting old and needed a magnifying glass to work on the small stuff.
midwestsurfguy is offline   Reply With Quote
Old May 6th, 2009, 04:40 PM     #7 (permalink)
Flash drive data recovery in <24 hours for $45
stutzmanryan is offline   Reply With Quote
Old May 6th, 2009, 04:58 PM     #8 (permalink)
cksboy15's Avatar
Send a message via Yahoo to cksboy15
or you could buy another flashdrive.
cksboy15 is offline   Reply With Quote
just formatted my hard drive :( how to recover data? CyberGhost General Tech Discussion 13 August 30th, 2007 08:39 PM
Who here on TechIMO can recover data from a dead drive? Micro Bean Storage Related 5 March 1st, 2007 12:30 AM
drive became Prpq---recover the file help nikhil Applications and Operating Systems 7 December 18th, 2005 01:17 PM
Recover from Failed Repair OldGuru Applications and Operating Systems 1 April 13th, 2005 09:12 AM
Can't recover secondary drive contents Jim A Technical Support 3 January 14th, 2005 11:45 AM
Is It Just Me? (1425)
Palin Resigning as Governor (31)
Budget PC Build, first time - Need .. (14)
[F@H SPAM 28 JUN 09] Today's the da.. (136)
Looking for Some good PC games. (7)
4gb RAM (7)
Worth upgrading GFX card? (34)
Toshiba Tecra A8 / Satellite pro A1.. (5)
Gigabyte 770 vs 790GX (cant decide) (7)
Crap, my graphics have gone to hell (17)
You guys might like this one (22)
Is this a decent gaming system??? (25)
Building PC for learning experience (18)
Need Technical Expierience (76)
Wireless Intellimouse (7)
4gb RAM (7)
Program crashes and blue screens (1)
DV6000 LCD Screen Won't Come On. (10)
Windows 7 Beta won't install (3)
files doing stupid strange things (27)
PC not Booting, problem with 4-pin? (0)
Windows Product Key (3)
New Graphic Card Question (4)
xp boot problem (1)
[F@H SPAM 28 JUN 09] Today's the day... (136)
Battlefield 2 Installation ERROR !! (11)
quick q (4)
Budget PC Build, first time - Need Ad.. (14)
Toshiba Tecra A8 / Satellite pro A120.. (5)
Brief pauses every few seconds on new.. (3)
Swapping computers (1)
Dell Dimension 3000 wont start proper.. (0)
need a laptop (3)
No signal to monitor at boot (4)
Trying to OC E7200 as much as possibl.. (1)
