Results 1 to 3 of 3
    Jun 2004
    72
    Problem with D: drive
    I have a desktop with (2) HD's C: is the operating system drive, and the D: is the storage drive. The computer is acting like the D: is not there. When you go to My Computer it shows the D: drive but will not allow you to right click or double click on it. Is there a way you can run check disk on the d: drive even though it has no operating system files on it?
    Mar 2002
    Under Your Bed
    8,909
    Sure!
    To repair errors, locate bad sectors, and recover readable information, just open a command prompt window (start-run, type cmd and click OK) and type chkdsk d: /r.
    Jun 2004
    72
    Thanks, I will try that.
  1. Boot drive letters; floppy drive problem
    By Theophylact in forum Technical Support
    Last Post: June 13th, 2006, 01:25 PM
  2. Problem with cd drive
    By smaltymgamer in forum General Gaming Discussion
    Last Post: January 2nd, 2006, 03:56 AM
  3. CD drive problem
    By fakan in forum Technical Support
    Last Post: April 11th, 2005, 02:33 PM
  4. DRIVE Problem
    By Kossy in forum Technical Support
    Last Post: January 1st, 2003, 02:45 AM
  5. Replies: 5
    Last Post: December 18th, 2002, 06:39 PM
