Maxtor HDD Won't Power Up
Currently Active Users: 2005
Discussions: 200,936, Posts: 2,379,237, Members: 246,301
Old July 26th, 2009, 10:53 PM   Digg it!   #1 (permalink)
I have a Maxtor DiamondMax Plus9 160gig ATA/133 hard drive that will no longer power up. I had been using it as a external HDD plugged into USB via a USB>IDE adapter (Came with a 4 prong plug that went into the wall). It was working fine and I had just thrown a bunch of music and videos onto it and didn't plug it in for a few months. I decided to plug it in today to give some of my videos to a buddy of mine and it wouldn't power up. Any solution other than sending it in to someone for 200+ dollars to get data off of it?
Zangofett2 is offline   Reply With Quote
Old July 27th, 2009, 02:43 AM     #2 (permalink)
LOL wow put it in your computer. see if that helps
kurazy is offline   Reply With Quote
Old July 27th, 2009, 04:50 AM     #3 (permalink)
As much as I'd love to it won't fit. I have an Antec300 case with 2 ATI 4870's xfired, a 3650, 2 other HDD, an aftermarket cpu fan (Pretty damn big), a CD drive (Obviously), a 850watt Corsair psu and wires out the ass everywhere.
Old July 27th, 2009, 04:57 AM     #4 (permalink)
Aaron_8015's Avatar
Send a message via MSN to Aaron_8015 Send a message via Skype™ to Aaron_8015
You dont need to fit it in there, im sure with those specs you must have an IDE slot not in use. Just hook the drive up and leave it next to the case.
Q6600//6gb//2x 260GTX//2x raptor + 750gb//Antec EA650//Lite-on DVDRW//Msi P7n D + X-Fi //Antec 900
''I dont suffer from insanity. I enjoy every minute of it.'
Aaron_8015 is offline   Reply With Quote
Old July 27th, 2009, 05:24 AM     #5 (permalink)
well said... if you dont have a space availible take the one from the cd drive. i pretty sure its EIDE
Old July 28th, 2009, 02:24 AM     #6 (permalink)
Yea, it is but the problem is with the power. (Only 1 IDE for CD as you said.) But, I will still try it, thnx for the help.
Old July 28th, 2009, 04:34 AM     #7 (permalink)
take it as well you can live with out a cd drive for a hour or so...
maxtor hdd sata sjr2377 Technical Support 3 June 10th, 2008 06:08 PM
maxtor hdd wolfeee General Tech Discussion 7 April 25th, 2004 05:01 PM
FS: Maxtor 40gb HDD embj Traders Forum: Buy, Sell, Trade 6 April 7th, 2004 01:16 AM
FS/FT 45GB WD 5400rpm HDD and a 60GB Maxtor 7200rpm HDD rourkchris Traders Forum: Buy, Sell, Trade 22 January 10th, 2003 10:06 AM
Maxtor 320 GB HDD Theophylact Tech News Discussion 15 September 11th, 2002 05:37 PM
windows 7 problem (6)
Is It Just Me? (2899)
CPU fan stops spinning randomly (6)
Wireless Televisions. (8)
California Passes Anti-Flat-HDTV Le.. (41)
Obama the Muslim (14)
Have you switched yet? (85)
Regular Build (4)
Modern Warfare 2 freeze (13)
wireless user (1)
favorit (1)
Fire in DVD (2)
Optical Audio A-B Switch (1)
