Major Hard Drive Problem .. need help ..
Currently Active Users: 2123
Discussions: 200,948, Posts: 2,379,394, Members: 246,309
Old September 18th, 2009, 11:44 PM   Digg it!   #1 (permalink)
Unhappy
Hello...
Thanks in advance to anyone who can help me with with a hard drive problem.
In a nutshell...
#1 PC stopped loading
Ran XP repair .. "unrepairable problem"
"Problem Hard Drive" is partitioned (C: & D: )
Need files from C:
Installed Problem HD as a slave drive on #2 PC.
Bios picked up Problem HD immediately
Loaded #2 PC...
Explorer did not display "Problem HD's" partitions C: or D:
Ran Computer Management...
Assigned Drive Letters to Partition C: and D:
Restarted #2 PC
Opend Explorer ... both of "Problem HD's" partitions are displayed
C: = "J" D: = "I"
I can access "Problem HD's" partition D: ("I") .. everything seems fine
When I try to access "Problem HD's" partition C: ("J") ..
Nothing Happens for a moment or Two and then I get error message:
"The disck in Drive J is not formatted. Do you want to format now?"
I open Computer Management and find out that Drive "J" is 30GB and has 30GB free space ....
HOWEVER .. this is not the case as this drive has not been erased or formatted.
I really need some files from this drive ...
is there a utility program or some way of accessing this drive?
I'm really stuck here and would GREATLY appreciate any help whatsoever!
Thank you for taking the time to read this lengthy post!
Wikaveli is offline   Reply With Quote
Old September 19th, 2009, 12:39 AM     #2 (permalink)
\m/(°-°)\m/
KarmaKiller's Avatar
Hmm.. the only thing that comes to my mind is put it in the freezer for a little bit. Sometimes the cold will "help" the drive run for the last leg of it's life.
Other then that, I'm not really sure what to tell you.
Good luck!
Folding for Team TechIMO!
Q6600@4ghz| Team Stats|
My RIG
Old September 19th, 2009, 04:39 AM     #3 (permalink)
Ride 'em Cowboy
The freezer trick won't help here...
Data Recovery like the following probably won't help either..You need to be able to access the partition...But, it won't hurt to try it.
Recuva (pronounced "recover") is a freeware Windows utility to restore files that have been accidentally deleted from your computer. This includes files emptied from the Recycle bin as well as images and other files that have been deleted by user error from digital camera memory cards or MP3 players. It will even bring back files that have been deleted by bugs, crashes and viruses!
Recuva - Undelete, Unerase, File Recovery - Home
Have you hugged your kid today??
Steve R Jones is offline   Reply With Quote
Old September 22nd, 2009, 11:06 PM     #4 (permalink)
Training for Bankai
JPMiller's Avatar
I would slave the drive to a second computer, and use "Data Lifeguard Diagnostic for Windows" on it
If there are unrecoverable sectors, it will fix them or replace them.
It may even give you the option to repair the MBR if it sees the issue
WD Support > Downloads > Select Product
Hard Drive problem Idris44 Storage Related 7 May 4th, 2009 11:23 AM
Advent 6411 Fit Hard Drive Major Problem LLAMEDOS General Tech Discussion 3 October 20th, 2004 11:11 AM
Possible Hard Drive problem PrttyTateMachine General Tech Discussion 2 November 14th, 2003 02:34 PM
Major Problem! Hard Drives wont boot! Redwolf General Tech Discussion 12 January 11th, 2003 10:55 PM
New Hard Drive problem macgybl General Tech Discussion 5 August 23rd, 2002 09:39 PM
Making Health Care Worse (171)
The disrespect of Obama by Russian .. (22)
Is It Just Me? (2935)
Regular Build (6)
Print spooler problem (15)
Graphics Card Upgrade Question (3)
How to convert MP3's (3)
Internet Lost (1)
Asus P4G8X Mobo (6)
Have you switched yet? (86)
sms storage to PC (0)
Regular Build (6)
Open With ..... Win7 (0)
java code for fibonacci (1)
