Don't worry, the clone won't have anything to do with hardware deficiencies.
that's a physical aspect of the drive itself.
any software issues, etc would of course carry over.
all you're doing is copying data, and the file structure.
if anything, once it's done and you're up and running, do a quick disk check and defrag, even if it doesn't need it to be sure it will have everything in place.
