BENQ DVD DD DW1620 problems
Currently Active Users: 1846
Discussions: 200,950, Posts: 2,379,442, Members: 246,312
Old October 17th, 2009, 09:02 AM   Digg it!   #1 (permalink)
(AKA) Nakamura
sweeper2's Avatar
i have a BenQ DVD-rw drive... under xp it worked correctly, recognizing dvd-rw's and cd's .. now it won't recognize any cd's or cd-r, cd-rw's .. only dvd's and dvd-rw discs ..IT does burn great to dvd-rw's .. no problems there... i have flashed the drive to the latest firmware .. I have also read online that this is a common problem with this drive but have yet to see someone post a fix to this.. I upgraded to Vista then re-formatted to Windows 7 Ultimate. this is the only thing causing me problems under windows 7 ... all the drivers are up to date etc...?
any thoughts or help would be appreciated
Windows 7 Ultimate
3600 x2 AMD 64 2.0ghz CPU
2 GB DDR400
Mach Speed Viper MK8-939A
Drive #1 - HDS728080PLAT20 (74 GB) (IDE)
Drive #2 - Hitachi Easy Device (596 GB) (USB external)
D:\ BENQ DVD DD DW1640 ATA Device (IDE)
P4 3.0ghz , P4M900-M4 , 450 psu , Sapphire HD 3850 512mb with an Accelero S1 cooler , 2gig pc5300 ddr2, 80gig Deskstar , 16x dvd-rw
Old October 17th, 2009, 10:16 AM     #2 (permalink)
osprey4's Avatar
Hi, Sweeper:
Does the drive recognize a bootable CD? That would be a way to test if the CD laser is actually working. Often, if a drive does not recognize CDs but does recognize DVDs, or vice versa, I suspect a laser failure. Of course, if this machine is a Dell, you could run the Dell diagnostics from a bootable USB drive.
Old October 17th, 2009, 01:03 PM     #3 (permalink)
batmeat's Avatar
Can you reflash to and older firmware?
How come Sour Cream can expire?
batmeat is offline   Reply With Quote
Old October 18th, 2009, 01:42 AM     #4 (permalink)
(AKA) Nakamura
sweeper2's Avatar
it does not recognize a cd .. but does recognize a dvd and burns dvd's ...
not sure about the older firmware.. I think i did reflash to an older one ... but i will look into that...
this is a (home built) pc .. not a name brand...
Old October 18th, 2009, 06:22 PM     #5 (permalink)
(AKA) Nakamura
sweeper2's Avatar
I tried flashing to an older firmware... still the same... it makes noise and the light blinks.. but then stops and doesn't recognize the cd ... but yet will read a dvd and burn dvd's just fine...? I ended up flashing back to the latest firmware and still the same... I guess I should look maybe for just a cd-rw drive.. ? or a dvd-rw drive... odd... if the laser was failing... i would think it would burn or read dvd's either...?
Old October 18th, 2009, 09:43 PM     #6 (permalink)
osprey4's Avatar
Did you even read my post?
Anyway, probably time for a new drive.
Old October 18th, 2009, 10:12 PM     #7 (permalink)
(AKA) Nakamura
sweeper2's Avatar
yes.. that's why i said why would it read a dvd and not a cd ...? i guess i'm not into diagnosing optical drives...
Old October 20th, 2009, 07:18 PM     #8 (permalink)
osprey4's Avatar
Go to Newegg for the drive. They have the best selection.
Benq DVD DC DQ60 Problems rp Multimedia and Audio 1 November 26th, 2006 07:55 PM
Benq 1620 Dvd +-rw hathor Technical Support 0 October 31st, 2004 02:24 PM
BenQ cameras Dax_Brandy General Tech Discussion 2 January 22nd, 2004 09:02 PM
BENQ FP557s opinions (TFT) SpookyEddy Graphics Cards and Displays 2 June 25th, 2003 10:56 AM
Is BenQ part of Acer? lynchmob General Tech Discussion 4 July 9th, 2002 06:13 PM
The disrespect of Obama by Russian .. (35)
Making Health Care Worse (177)
Is It Just Me? (2941)
Regular Build (7)
Print spooler problem (15)
Internet Lost (2)
Regular Build (7)
How to convert MP3's (4)
Asus P4G8X Mobo (6)
Have you switched yet? (86)
sms storage to PC (0)
Open With ..... Win7 (0)
java code for fibonacci (1)
