Results 1 to 3 of 3
    Dec 2004
    Golden, CO
    138
    What file differences are there between mirrored system disks?
    Here at work, for a few of our main systems running, we have mirrored "backups" if you will that we can boot to if for whatever reason the main boot disk gets messed up. We have actual backups as well, not really trying to say we use disk mirroring as a back, 'cuz that'd be retarded. Just added redundancy. So being that when you mirror to a second disk, you are in effect, making an exact copy of your current disk... what then are the file differences between the two? And if those file differneces did not exist, what could happen? Someone asked me this question and I wasn't quite sure how to answer it
    This is all done on UNIX systems btw, if that matters.
    Si vis pacem, para bellum
    Ultimate Member BipolarBill's Avatar
    May 2002
    Northern New Jersey
    2,724
    There should be no file differences between the two. All files are written to both drives simultaneously.
    Keep in mind that the drives require connection to the RAID adapter to work.
    MCSE, MCP and nut job
    Mar 2007
    My own little world.
    11,764
    RAID 1 is where you have "mirrored disks" and each disk is exactly the same size, meaning you lose out on overall capacity but have the ability to have a disk fail (or be removed as a basic kid of backup strategy) and replaced and rebuild the mirror.
    RAID 0 means that all drive space is added together, but if any disk fails, the lot is gone - as it would be with a single disk.
    RAID 5 is like a combination of the two, where you get more space (but not the overall total) with the ability to have a disk failure, as data is written across all three (or more) disks. It does not however allow for a disk to be removed from the array as a basic level backup - as RAID 1 can...
    RAID 10 is actually a combo of RAID 1 + 0 (hence 10) and spreads data over (normally) 4 disks and gives the speed and space advantages from RAID 0 while having the redundancy that you get from RAID 1...
  1. How do I change a FAT 32 File system to a NTFS filing system
    By kozuch in forum Applications and Operating Systems
    Last Post: January 5th, 2010, 09:12 AM
  2. system recovery disks
    By Mombo323 in forum Applications and Operating Systems
    Last Post: November 9th, 2009, 08:55 PM
  3. C Drive Missing On Mirrored NT 4 System
    By jwalsh in forum Technical Support
    Last Post: September 4th, 2003, 11:19 AM
  4. boot from mirrored drive
    By Avery_Stiles in forum Technical Support
    Last Post: August 4th, 2003, 06:55 AM
