Results 1 to 10 of 10
    May 2009
    Hendersonville NC
    16
    Drive 0 not found: Serial ATA, Sata-0
    Ok, so I was going to uninstall Oblivion due to my own fault.
    The launcher said to find the .exe on the CD so I opened my F Drive (DVD BR) and clicked on something that sparted with MSoft, it was very quick and did happen to uninstall oblivion, However now my Drive is gone and the open button will not work, It's not listed under My Computer anymore and when I reboot it gives my this message.
    Drive 2 not found: Serial ATA, Sata-2
    The basic press F1 to continue and F2 for settings.
    I did a System restore hoping that would fix it but it didn't. Allthough it did bring oblivion back so now I'm just pissed off. Is there anyway to fix it?
    If it helps I'm using Vista 32 bit.
    May 2009
    Hendersonville NC
    16
    I've figured out that I need "BD-RE BDD1001 driver software" Anyone know where to obtain this?
    South Jersey
    11,368
    All optical drives use the same generic drivers. This is a BIOS issue, so system restore is a waste of time and effort. I would try resetting BIOS defaults.
    May 2009
    Hendersonville NC
    16
    Quote Originally Posted by osprey4 View Post
    I see, That would make sence as to why nothing happend apon restore lol.
    So resetting the BIOS huh? Is that something I could do easily? How would one go about resetting the BIOS anyway?
    South Jersey
    11,368
    I don't know what system you have but normally you boot to the BIOS, look around and find the place where you set BIOS defaults.
    May 2009
    Hendersonville NC
    16
    I have an XPS410 but thats just a model, Not sure what my Operating system is called. I googled what you said and found a wiki on it. Do I really have to mess with the hardware?
    How to Reset Your BIOS - wikiHow
    Millwright stroyal's Avatar
    Dec 2002
    New Hampshire
    8,059
    That is a jumper reset, you probably only need to reset in the BIOS set up screens.
    No operating system involved.
    When the computer first starts, if you can see the POST screen ( displays drives and counts the memory ect.), at the bottom of the screen it will say press XX to enter setup.
    You have to press XX before that screen goes away.
    On the Dells I have XX is F2, but some used the Delete key.
    If you can't see the POST screen, just start pushing the F2 key repeatedly, as soon as you start the computer.( don't hold it down)
    If that doesn't work, try the Delete key.
    When you get in, the first screen is the menu, usually 1 of the items is "set to default" or something like that.
    Let us know how you make out, or if you have trouble getting into the BIOS.
    Hard Sayin Not Knowin
    South Jersey
    11,368
    May 2009
    Hendersonville NC
    16
    Ok, heres what happened. It was F2 that took me to the System screen
    I looked it over and dicided that Boot Sequence was my best bet. I wasn't sure what to look for, nothing said BIOS. However under boot sequence I got this.
    1. Onboard or USB Floppy Drive
    2. Onboard SATA Hard Drive
    3. WDC WB3200AAKS-755BA
    4. Onboard or USB CD-Rom Drive
    5. USB Device
    Numbers 3,4,5 could not be found.
    Member RacerX's Avatar
    282
    Um, you were in the BIOS, there isn't something you look for in there that says it. The BIOS is what stores the hardware settings for the computer. The F2 gets you into the BIOS (settings)
    the fact that it reads: 3. WDC WB3200AAKS-755BA tells us the BIOS is recognizing that drive as existing, plus you said you still got in and ran a system restore.
    Sounds like we need more info. How many hard drives and optical drives do you have, so we can determine what's actually missing in the BIOS, and are they SATA or PATA?
    E8400 @ 4.2Ghz (1.18-1.29v)||DFI UT P45-T2RS ||HD6950 (Unlocked Shaders) @ 950/1450||8Gb G-Skill DDR2||Dual Boot: XP=500GB , Win7=120GB Agility SSD, Shared D drive=1TB, Int/Ext 1TB backups.
  1. Serial ATA vs SATA
    By wyattearp in forum Technical Support
    Last Post: September 28th, 2009, 10:05 PM
  2. Serial ATA? SATA?
    By Confidence in forum Motherboards
    Last Post: June 24th, 2008, 04:40 PM
  3. Ultra ATA and Serial ATA!?!
    By Bgator in forum Storage Related
    Last Post: April 19th, 2006, 06:30 AM
  4. Replies: 0
    Last Post: February 20th, 2005, 11:01 PM
  5. Serial-ATA WD Hard Drive
    By Rec0n in forum General Tech Discussion
    Last Post: January 12th, 2005, 11:47 PM
