May 9th, 2010, 11:01 AM #1Junior Member
- May 2010
- 1
SanDisk 2.0GB memory suddenly "unreadable" HELP!
I have a 2.0 GB SanDisk memory card containing a lot of important college work etc. It was working fine about 10 minutes ago when I was uploading some files from my Windows computer, but when I removed the card reader and put it into my MacBook it said 'This disk you inserted was not readable by this computer.' and I couldn't view any of my files that I'd seen just a few minutes earlier! Then, I tried inserting it back into the Windows computer and had the same problem - it asked me if I wanted to format the card but this would mean losing everything on there and it's really important that that doesn't happen. I'm sure this happened once before and I just restarted the computer and left it a while and it sorted itself out... but now I don't know what to do. Please help, I'm really worried that all my work is lost.
May 9th, 2010, 02:06 PM #2
Didnt you leave the copies on the computer you transfered them from...? As you are copying to a different device it would leave a copy on the machine...
May 9th, 2010, 02:13 PM #3
its possible the card went bad, its possible you pulled it out while it was still writing data, corrupting the card.
see if anyone else has a card reader on their laptop or PC, and try the card out there, if it reads fine, then back up the data some how (burn to disc comes to mind), and its probably a bad card reader, if its still unreadable on a known working card reader, then your card is pretty much FUBAR, with out going to a Data Recovery Service, which can be insanely expensive, your pretty much S.O.L..i7 940//Corsair H60//EVGA X58 SLI LE//6GB Corsair Vengeance 1600MHz//2x EVGA GTX 560 Ti FPB SLI//NZXT Hale82 850W//CM 690 II Advanced//Win7 64//WD 74GB V-raptor, 750GB Black, 1.5TB Green
SanDisk 1.0 GB camera memory card "Write protected" (x-post)
By daxzzler in forum Technical SupportReplies: 6Last Post: July 24th, 2010, 06:44 PM -
BIOS & OS suddenly "loose" 5 yr old slave HD
By SirLoinn in forum Technical SupportReplies: 4Last Post: April 16th, 2009, 05:56 PM -
LAN connection on third computer suddenly "unplgged"
By abdul.jones in forum Networking and InternetReplies: 7Last Post: August 31st, 2007, 07:01 PM -
I get"Out of Memory",or"insufficient memory"Error Messages with Large Amounts of
By soulja in forum Technical SupportReplies: 17Last Post: June 6th, 2003, 01:29 AM -
"The partition table on device hda was unreadable"......grrrrrrrrr.....AHHHHHH!!!
By newbie~wan in forum Applications and Operating SystemsReplies: 16Last Post: January 6th, 2002, 02:23 PM
Wow, that's a lot of information to process, but it will all be put to good use. Thanks a ton. I usually preferred NVIDIA cards in the past as well. My bias was less educated, naturally, but I...
Suggested upgrades for a Gaming...
