Results 1 to 4 of 4
    Oct 2004
    4
    120G External Drive, USB 2.0: Works on USB ports, not on USB 2.0 PCMCIA Buscard port
    Using a Lenovo R61e, WinXP.
    My new USB 2.0 PCMCIA card works with all of my USB-connected devices, EXCEPT with my USB 2.0 120Gb external hard drive (also new).
    The 120 Gb drive works fine with my standard USB ports on the laptop (but not at USB 2.0 speeds of course).
    I couldn't find anything to address this, so I'm goin' to the experts!
    Any suggestions, dear readers?
    South Jersey
    11,368
    Is this a "portable" drive? It's very common to see power issues with these.
    Oct 2004
    4
    Yes, it's a portable drive. When using the regular USB port the drive's red light is steady on. Not so when plugged into the USB 2.0 port.
    Millwright stroyal's Avatar
    Dec 2002
    New Hampshire
    8,059
    If it is a power issue you can get an external power supply.
    Either or both your drive, and/or your PCMCIA card should have a place to plug one in.
    They are 5volt, I forget how many amp.
    You can also get a powered hub.
    Hard Sayin Not Knowin
  1. USB drives or external USB hard drive?
    By Mombo323 in forum Applications and Operating Systems
    Last Post: January 20th, 2007, 06:56 PM
  2. USB Port on PCMCIA won't work
    By hinghing1113 in forum Mobile Computing
    Last Post: November 30th, 2005, 08:54 PM
  3. Replies: 2
    Last Post: October 21st, 2005, 09:08 PM
