Results 1 to 4 of 4
Thread: dvd motor bad?
    Mar 2011
    dvd motor bad?
    hope i'm posting in the right place...i have a lite on dvd burner...i know, stop buying lite on. replaced with an ASUS but i took it apart, hoping it just needed a cleaning. Yes, i know enough to take it apart and put it back together safely. done it with various other components. my only problem is, the spindle motor used for spinning the disk rattles. sounds to me like loose ball bearings. i assume this is a bad motor but just wanted a more experienced opinion, since this is the first dvd rom i've taken down this far. others i fixed were much simpler.
    South Jersey
    11,368
    Hi Ninjajoe99,
    Welcome to TechIMO.
    I've never disassembled the spindle of a DVD drive but I rather doubt they're built with ball bearings. But if you have a spindle problem, there's no fixing the thing, so you might as well take it apart and see what you find.
    you like me -FMA's Avatar
    Oct 2004
    Michigan~
    3,475
    Nothing wrong with Lite-on IMO, I've been happy with them.
    DVD burners can be had for about $20 after shipping so just open it up and see what you find. It's an inexpensive part to replace.
    Cute
    South Jersey
    11,368
    If you can, post a picture.
  1. Bad backup to DVD-RW
    By dsp128 in forum General Tech Discussion
    Last Post: March 14th, 2008, 03:18 PM
  2. PC DVD Playback bad :(
    By Rootstonian in forum General Tech Discussion
    Last Post: April 17th, 2007, 01:03 PM
  3. Laptop DVD problem..is it bad?
    By John Prophet in forum Technical Support
    Last Post: April 14th, 2004, 04:20 PM
  4. Bad Sound on one DVD drive
    By blubomber in forum Technical Support
    Last Post: May 15th, 2003, 03:30 PM
  5. Bad DVD Drive
    By cracked in forum Storage Related
    Last Post: April 17th, 2002, 06:10 PM
