Results 1 to 5 of 5
    Jun 2005
    473
    Connecting multiple hard drives to USB Hub
    After looking at all kinds of options, I am planning on purchasing multiple 2 or 3tb external hard drives that i will connect all through a 10port POWERED USB Hub.
    I have read reviews on this hub where one user said he had multiple flash drives connected to it and Windows picked up every single one of them fine.
    What i want to do is buy these hard drives in pairs so i can software mirror raid them.
    They are to be used as active storage whenever i need to access or move something over to them.
    Besides that, they are shut off.
    For the short time i will use them in a day, software raid is perfectly fine with me as i do not need performance anyways, redundancy is more important here.
    Question i'm wondering is.. since i've never used a powered hub before, can a 10port powered hub really allow the control of up to 10 hard drives through one usb cable?
    Specs say with the power cord connected, it gives 500mA per port so i know that's plenty.
    Will booting up 10 drives in a software raid be ok? Never done software, just hardware raid.
    I have a core2quad q9300 @3.4ghz, 4gb of ram.
    I typically have about 35% memory free.
    I got the page file turned on because there are instances where i go over 4gb.
    I may need to up my setup to 8gb soon.
    NOVA
    34,642
    58
    I dont recommend doing what you are considering doing
    Senior Member evereddie's Avatar
    Feb 2004
    Between NY and Miami
    937
    Quote Originally Posted by GroundZero3 View Post
    I don't recommend doing what you are considering doing
    Might be good advice but the most important thing is missing from your post. WHY.
    I would get an add in card for your computer that is USB 3 and has a mess of ports. One with 4 ports would not be hard to find and not be very expensive. Hook each drive into it's own usb port. JMHO
    NOVA
    34,642
    58
    Well for one, the speeds would be abismal, do I need to go on? This just isnt how you do things, you dont plug 10 hard drives into a usb hub and do a software raid on it.
    If it was one or two drives I would say hey that should be okay for a backup solution. But 10? Come on now.
    Jun 2005
    473
    ok, hehe, i just found another option that will work out for about the same price...
    2 port multiplier cases, hardware raided, holds up to 24TB total.
    I'll be goin with, not immediately, to 8TB on 1 case..
    that should hold me over for quite a while.
    By the time i need to purchase the other one, 3 and 4tb drives will be greatly reduced in price.
    Comes with a free PM supported dual esata hardware raid controller.
    It's very nice for the price and great reviews too.
    1 8TB setup is $429.
    1 12TB setup is $589.
    So basically I get the same thing, but only spending a few dollars more to have it all hardware controlled which is a plus.
What is 10 and 5 added together?
  1. USB drives or external USB hard drive?
    By Mombo323 in forum Applications and Operating Systems
    Last Post: January 20th, 2007, 06:56 PM
  2. Multiple OS, multiple Hard Drives?
    By CoonDawg in forum Storage Related
    Last Post: June 16th, 2006, 08:52 PM
  3. Multiple hard drives- MAX I can install?
    By v6killa in forum Storage Related
    Last Post: February 23rd, 2006, 09:15 PM
  4. RAID-0 on multiple Firewire/USB 2.0 external disk drives?
    By ProvingGrounds in forum Storage Related
    Last Post: July 15th, 2004, 07:56 PM
  5. External Multiple Storage Hard Drives Case
    By MegalosSkylaki in forum Storage Related
    Last Post: July 1st, 2004, 08:19 PM
