Results 1 to 5 of 5
    Amazing Member truckpuller's Avatar
    Jan 2004
    Verona Missouri
    5,514
    Hard Drive Capacity
    I have a seagate 500GB hard drive and i was in properties for C\ drive and noticed it showed only to be 372GB capacity and actually it shows 399,981,408,256Bytes. I have 77.1 gig loaded on hard drive and said i have 295GB free space...im running windows 7 64 bit.. what gives.
    Jan 2003
    Outside the box
    8,489
    4
    Is the drive partitioned for the full 465Gbs or so that would be the actual size? any hidden partitions like a recovery drive? JP recommends this tool often
    Quote Originally Posted by JPMiller View Post
    JAM Software - Windows Freeware
    try treesize free
    it will tell you whats using up space
    should allow you to see where some of the missing space is. But for the actual drive capacity double check disk management and make sure of the partition space.
    Jan 2004
    Verona Missouri
    5,514
    Yes its suppose to be for the full 465 Gbs drive partition and no hidden partitions. Thanks i'll try that.
    Jan 2004
    Verona Missouri
    5,514
    Nevermind..my bad..i had another senior moment again it's only a 400GB hard drive i just pulled the cover and looked..thanks Rich... that is a cool program though tells you pretty much everything on the hard drive.
    Jan 2003
    Outside the box
    8,489
    4
    Ahh those senior moments You can thank JP for that app I have yet to try it out but I know he recommends it fairly often.
  1. Hard Drive Capacity Problem
    By Vemisery in forum General Tech Discussion
    Last Post: August 20th, 2004, 10:15 PM
  2. Hard Drive Capacity
    By Wayne Owens in forum General Tech Discussion
    Last Post: July 30th, 2004, 04:18 PM
  3. hard drive not showing full capacity
    By roseygirl in forum Storage Related
    Last Post: July 25th, 2004, 01:36 PM
  4. Replies: 6
    Last Post: September 27th, 2003, 09:11 PM
  5. Hard Disk Formatting Capacity
    By DennisLo in forum Storage Related
    Last Post: August 16th, 2003, 01:53 AM
