Harddrive problem
Currently Active Users: 1732
Discussions: 200,909, Posts: 2,378,936, Members: 246,276
Old January 22nd, 2003, 06:29 PM   Digg it!   #1 (permalink)
Harddrive problem
I have a 3.2 gb JTS harddrive that seems to have died, but I would like to try all possible remedies to retrieve some data.
No matter how I install it (secondary master, slave or cable select), at boot I get the message:
"Secondary Master Drive - ATAPI Incompatible
Press F1 to Resume"
When I press F1, the machine finishes the boot sequence as normal, but the secondary drive is not visible, either by Windows or Norton Disk Doctor.
Question: Is it dead, or is there something else I can try?
(I have tried changing cables, computers, etc.)
txds is offline   Reply With Quote
Old January 22nd, 2003, 06:31 PM     #2 (permalink)
Wizzard~Of~Ozz's Avatar
Send a message via ICQ to Wizzard~Of~Ozz Send a message via MSN to Wizzard~Of~Ozz
Sounds to me like the cable is bad, there is no power to the drive or the board is blown/damaged. So you can try slaving it off the first drive, try using a different power connector, if not then there are places that offer data recovery (for a fee) if it's that important.
Wizzard~Of~Ozz is offline   Reply With Quote
Old January 22nd, 2003, 06:40 PM     #3 (permalink)
Well, I've tried all those suggestions to no avail.
The data is not (at this time) worth the cost of the data recovery "Professionals"!
Old January 22nd, 2003, 06:45 PM     #4 (permalink)
korgul's Avatar
Have you tried to set the cylinders heads and sectors in the BIOS?
korgul is offline   Reply With Quote
Old January 22nd, 2003, 06:49 PM     #5 (permalink)
No. Can I do that even though the drive is not listed?
Old January 22nd, 2003, 06:54 PM     #6 (permalink)
It had been a while since I looked at the bios setup. I am trying that right now.
Old January 22nd, 2003, 07:00 PM     #7 (permalink)
The BIOS will not allow me to enter the Cyln and Head data, even though I have selected "User" as the Type.
Using "Auto" results in a prolonged search with no results.
What is the significance of the "ATAPI Incompatible" error message?
Old January 22nd, 2003, 07:01 PM     #8 (permalink)
It means the controller is communicating something that it doesn't recognize, (jibberish) so it is saying that it is not an IDE drive.
Old January 22nd, 2003, 07:07 PM     #9 (permalink)
Does that mean that it does in fact find the drive?
But for some reason it can't communicate with it?
If so, are there any suggestions along this line?
Is It Just Me? (2815)
HIS HD5770 graphic card question (14)
Foreign voltage (6)
Print spooler problem (7)
EVGA 9800 gtx help with finding a g.. (7)
Mysterious Boot manager (9)
Asus P4G8X Mobo (3)
windows vista security holes (2)
World's largest Monopoly Game using G.. (329)
EVGA 9800 gtx help with finding a goo.. (7)
Need hard disk drivers (4)
Boot Problem? (0)
Logitech G9 laser gaming mouse $59.95.. (2)
$5 off any item with the purchase of .. (1)
Foreign voltage (6)
hybernate option (2)
