rebuilding old 166 -- CD's won't work  | | |
February 9th, 2003, 06:37 PM
#11 (permalink)
seems I've forgotten too much DOS! What is the switch with a "type" command to make it paginate? Forgot to change the jumper to master on the Iomega drive, but it is recognized on boot via the floppy.
And also, CBB, the old Mat drive is definitely NOT a CDRW, it's a 2x CDR [or in this case, NOT R!] |
February 9th, 2003, 06:42 PM
#12 (permalink)
Ok, What do you mean paginate?
Not sure I know that word, but if you mean page break, it's
Type blah.txt |more
And for directories, it's just dir /p
And Throw that matsushita drive out, unless you have the old soundcard it was hooked up to and a tonne of patience (and that time is not worth the 25$ to replace it with a faster drive that's IDE  )
February 9th, 2003, 06:47 PM
#13 (permalink)
thanks, wiz, forgot the space between the t and the pipe
just did it -- "type readme.txt |more" doesn't
February 9th, 2003, 06:50 PM
#14 (permalink)
np, so you have it working how you want it? less that old CDrom ofcourse
Let us know if you need some more help with it. |
February 9th, 2003, 06:52 PM
#15 (permalink)
no, wiz, how do I get the CDRW to go from the a: prompt? |
February 9th, 2003, 06:57 PM
#16 (permalink)
Well, When it boots, did it tell you what drive letter the CDrom was assigned to?
just type in x: (X is your CDrom drive letter) then hit enter
Then you are on the CDrom drive. AFAIK you cannot set the CDrom to be drive A:.
If it doesn't tell you the CDrom drive letter, let me know what bootdisk you ran and I'll letcha know. |
February 9th, 2003, 07:05 PM
#17 (permalink)
don't know which drive -- tried b,d [only one HDD],e,f,g and h. didn't like any of them. booted with a 98SE floppy |
February 9th, 2003, 07:06 PM
#18 (permalink)
Have you tried Y: ? some disks like doing that, or X: those are the typical 2. |
February 9th, 2003, 07:08 PM
#19 (permalink)
not x or y, either. gotta break for 15, BRB |
February 9th, 2003, 07:11 PM
#20 (permalink)
Some Packard Bells automatically assigned the single CD-ROM (or CD-RW) as drive "Q". |
