maxtor hard drive problem  | | |
February 17th, 2003, 05:26 PM
I just bought a maxtor hard drive, Diamond max plus 8 30gig when i open my computer in windows 98 it says its only 7.82gig, Any ideas whats causng this? |
February 17th, 2003, 05:33 PM
Is this the only drive you have or is it a slave? If it is a slave have you tried to fdisk and format it? |
February 17th, 2003, 05:35 PM
| | Fossil
What's your machine? Older BIOSes could only handle 8.4 GB (although Maxtor's EZ-BIOS overlay can get around this limit). |
February 17th, 2003, 05:37 PM
What motherboard did you install this on, you may have hit an 8Gig limit, Usually software that comes with the drive will allow you to overcome BIOS limitations of the motherboard. (Maxblast software)  Theo beat me to it  |
February 17th, 2003, 05:38 PM
| | Si vis pacem, para bellum
What are your system specs?
There were barriers to older systems in regards to what the BIOS could recognize. Fairly old systems had a BIOS that could not recognize anything above 8GB. Then there was a 32GB limit and now there is a large limit, which I can not remember the numbers (over 100GB). Your Maxtor installation disk has options for installing the MaxBlast software. It is not well written software, but ti should get your system to see the drive in its entirety. |
February 17th, 2003, 05:39 PM
Its a new motherboard gigabyte ga-7vkml athlon 2000+ xp its the only drive i use, And its on master just installed 98 formatted 1st |
February 17th, 2003, 05:42 PM
Ok, forget my post then. That mobo has a new enough BIOS for this to not be a factor.
What does FDISK say? If you format in DOS with a 98 boot disk, does it show the full 30GB? |
February 17th, 2003, 05:45 PM
| | Pump you sucker! Pump!
Did you choose to format with fat32? You must use this for large drives in win 98.
Ignore me, it's been so long since 2 gig was large..!
Edit: Welcom to TECHIMO, as you can see we are all eager to help!
Obama has taken America from purported bully to notorious chump in less than a year.
February 17th, 2003, 05:46 PM
Fat16 would have formatted it as 2GB partitions. If he gets 7.x GBs of data, he must have formatted it with FAT32.
edit: lol, Theophylact. |
| | Fossil
Must have, or he'd only see 2 Gig partitions. daveleau, beat me to it! |
