March 9th, 2003, 02:00 PM
| DO I need a large power supply for a large disk?
I am considering replace the 10G hard drive in my 4 year old HP Pavilion 8533z with a 120G hard drive.
Do I need a new, large power supply for the hard drive?
Thanks!
Jim |
March 9th, 2003, 02:03 PM
If you are replacing it then you should be fine, as long as you don't have a bunch of other hardware (like high end vid) you'll be fine. |
March 9th, 2003, 04:21 PM
You should be fine; I think the only part of a hard drive that really needs a lot of power is the motor turning the platters.
I'm pretty sure that the power requirements for my 40GB and my 120GB are about the same. |
March 9th, 2003, 04:32 PM
Just curious, Jim:
What wattage power supplies did HP put in those PCs 4 years ago, 230 or 250 watt? You should be OK, I was just curious.
- Bill |
March 9th, 2003, 05:26 PM
250 W or 230W?
Nope!
It is a 160W power supply. |
March 9th, 2003, 11:35 PM
| | Human voltmeter
HOLY CALF! That's a pretty small PSU. Well if it ran fine with a 10GB drive then it should run fine with a 120GB drive. Unlike processors, the power requirements for HDDs don't go up. The main consumer is the motor... and that hasn't changed much in years. |
March 9th, 2003, 11:38 PM
I would change the power supply to like a 300W.. its not needed but it would make your computer run a little better in performance |
March 10th, 2003, 12:00 AM
Is it one of those extra small psu's?
Or a normal/standard sized one?
PyroSama
JOIN [FaD] | TEAM NUMBER 2037 | http://www.techimo.com/forum/t121132.html
March 10th, 2003, 03:04 AM
Many HP's with that small a p/s don't have room in the case for a standard 250 or 300 watt p/s. These little p/s are sometimes referred to as micro-atx. They will run anywhere from 90 watts to 180.
Benjamin Franklin
March 10th, 2003, 11:58 AM
I say why bother replacing the PSU, if it works don't fix it if it fails then replace it. no sense putting a huge power supply into a system taht will not use anything over the 160w that it will provide. |
