Results 1 to 4 of 4
    Senior Member grandchehaw's Avatar
    Mar 2002
    Grand Rapids, MI
    501
    Anyone use FireBurner? I am having a problem....
    I just bought a new Lite-On 52x24x52 CD-RW drive. It works great in Nero but I can not burn a CD using FireBurner. I have the latest version of FireBurner which is 2.1.7. This is the error I am getting
    Thread1: Executing (Cache enabled)
    Recording device: LITE-ON LTR-52246S
    Firmware version: 6S07
    Recording method: Session-at-once
    Recording Speed: Max
    BURN Proof: Enabled
    // Burning - data is being permanently written to CD
    Thread1: Setting Write Parameters
    Thread1: Error setting write parameters
    Thread1: Error starting burn - Retrying...
    Thread1: Write parameters set
    Thread1: Reading Disc Info
    Thread1: Reading Next Track Info
    Thread1: Start LBA is -150
    Thread1: Sending Cue Sheet
    Thread1: Processing Track 1 Pregap [150 Sectors]
    Thread1: Processing Track 1 [Mode1] [319711 Sectors]
    Thread2: Executing
    Thread2: Write Error @ Sector -123
    Thread2: Sense Error: UNIT_ATTENTION (POWER ON, RESET OR BUS DEVICE RESET OCURRED) (0x06 0x29 0x00)
    Thread2: Synchronizing Cache
    Recording complete
    I am not sure whats going on but I have toasted two CD-R's trying. :-/
    TIA.
    -JR
    Ultimate Member rpertusio's Avatar
    Nov 2002
    1,349
    I haven't seen this error specifically.
    Have you (successfully) burnt the same project with Nero?
    Have you tried burning a different project with FireBurner?
    If you are comfortable with updating the Firmware of your drive, you can visit LiteOn's Firmware page and download the latest firmware for the LTR-52246S
    If you have a CD-RW disc (instead of a CD-R) that will let you keep trying different stuff without 'wasting' CDs.
    - rp
    Mar 2002
    Grand Rapids, MI
    501
    I can't burn the same project with Nero. I use Nero for odds and ends and ISO files. I use FireBurner for BIN CUE files. I was able to use FireBurner with my Lite-On 24x burner without any problems.
    Retired mostly.
    Finland
    5,150
    You do know that later nero versions support bin/cue format too?
    At least 5.5.x.x does, update your nero and you won't need fb for that.
    -M
