Seagate Barracuda Problem!
Currently Active Users: 1167
Discussions: 200,929, Posts: 2,379,148, Members: 246,296
Old April 8th, 2003, 04:51 PM     #11 (permalink)
Etruscan's Avatar
I don't think you have a problem, if you can see that the volume on the drive is 7.5GB. It is probably just a quirk in the defrag program. It may be counting space used as virtual memory by windows as space used. Or, it may be some other as yet unknown parameter of HDD use by WindowsXP.
Etruscan is offline   Reply With Quote
Old April 9th, 2003, 10:06 AM     #12 (permalink)
phrozen_dreamz's Avatar
It's not Virtula memory either...It's set at 256mb. This ticks me off. I've never had this problem before.
When you began, we ended.
phrozen_dreamz is offline   Reply With Quote
Old April 9th, 2003, 10:10 AM     #13 (permalink)
tmx468's Avatar
IN my computer, right click on the drive - how much free space is listed?
tmx468 is offline   Reply With Quote
Old April 9th, 2003, 01:18 PM     #14 (permalink)
There it also says that there is 27GB taken up! This is impossible. I dont even own 27GB of software.
Old April 10th, 2003, 10:06 AM     #15 (permalink)
~Bump~
Old April 11th, 2003, 04:12 PM     #16 (permalink)
Bumpy
Old April 11th, 2003, 06:29 PM     #17 (permalink)
prexaspes
Posts: n/a
Have you done a checkdisk lately?
Right click on the drive and get to the tools tab. Error checking status or something. You'll have to restart the PC so it can run the program.
Edit - Did you Fdisk when you reformatted?
Is It Just Me? (2868)
Obama the Muslim (14)
Regular Build (3)
Fire in DVD (2)
Have you switched yet? (84)
Optical Audio A-B Switch (1)
Virus Doctor Popup? (1)
