Whats the difference between SD & MMC memory cards?
Currently Active Users: 1351
Discussions: 200,928, Posts: 2,379,143, Members: 246,295
Old April 16th, 2003, 10:38 AM   Digg it!   #1 (permalink)
JayMan's Avatar
Send a message via ICQ to JayMan
Hey all,
I just got myself a nice 2MP digital camera (was pretty cheap, and i'm happy with the quality of it so far).
It came with 16MB memory built into it, which doesn't really last all that long when setup for best quality pictures. The manual says the camera supports MMC & SD memory cards for expansion memory, but it doesn't say what the difference is between them.
I wanna buy some more memory, probably 64MB depending on the price..... Will i notice any functionality difference or performance difference between the 2 types? or will they be pretty much the same? Which is usually cheaper?
Which would you all choose to buy?
Thanks in advance
JayMan
JayMan is offline   Reply With Quote
Old April 16th, 2003, 06:55 PM     #2 (permalink)
omega31's Avatar
http://www.geocities.com/romidar/mmcvssd.htm
SD is generally faster than MMC. SD incorporates "cryptographic security for protection of copyrighted data," whereas MMC does not. SD is also somewhat more durable, having a somewhat thicker casing than MMC. Pricing at the moment has the SD card cheaper than MMC, although not too long ago SD was considerably more expensive.
3 articles:
http://www.woodyswatch.com/palm/archtemplate.asp?2-n12
http://asia.cnet.com/reviews/digital...9008492,00.htm
I have a MP3 player that supports SD/MMC. I bought MMC at the time.
omega31 is offline   Reply With Quote
Old April 16th, 2003, 10:56 PM     #3 (permalink)
JayMan's Avatar
Kewls, thanks for the links, i'll check em out when i get a couple minutes...
From what ya said, it seems SD would be the way to go with it being faster, more secure, more durable & cheaper...
JayMan
Is It Just Me? (2867)
Obama the Muslim (14)
Regular Build (2)
Fire in DVD (2)
Have you switched yet? (84)
Optical Audio A-B Switch (1)
Virus Doctor Popup? (1)
