Join TechIMO for Free!
Thread Tools
Currently Active Users: 2807
Discussions: 186,707, Posts: 2,228,134, Members: 230,362
Old May 29th, 2003, 09:39 AM   Digg it!   #1 (permalink)
HDD's starting then stoping coming out of sleep running APM
Running 2k w/ APM support (no ACPI because of chipset issues) after the HDD's power down (after 10 min as I have set it) when they are started, they go into a 'loop' pattern of trying to start, then stop over and over. Usually I have to force a reset to get out of it, but sometimes I can get Task Mamanger uip and it seems to keeps the drives up and running.
I know if I set the drives to 'never' would solve the problem, but that isn't what I want to do, nor is it a real 'fix'!
ACPI was changed over to APM because of issues between 2k's ACPI mode and the Ali V chipset. Again this is 2k w/sp3 installed and regular ATA33 IDE drives on the same channel.
videobruce is offline   Reply With Quote
FREE instant scan
Old May 29th, 2003, 10:06 AM     #2 (permalink)
Let's go, Hokies!
osprey4's Avatar
That's exactly what I would suggest. I have yet to see anyone claim that allowing drives to spin down saves anything. And it certainly creates headaches of all sorts.
Old May 29th, 2003, 10:15 AM     #3 (permalink)
PCLinuxOS MiniMe 2008
dunbar's Avatar
Send a message via ICQ to dunbar
OTOH, a Compaq Deskpro where I work started acting similarly under W98SE. SMART was initially disabled, but when the drive began to refuse to spin up, I enabled SMART services in the BIOS, for the purpose of testing the hard disk. The hard disk was throwing SMART error 1720 at each bootup for a few days, then the drive began to get very reluctant to spinup. It turned out the drive was actually dying (for real), and CompaQ just replaced it. Maxtor 40Gig, 18 months old, 3 year warranty. YMMV.
--Tell the Linux developers to write accurate and timely docs 'cuz they read their own code the best. Tell them to put them in the system, too.
dunbar is offline   Reply With Quote
Old May 29th, 2003, 11:28 AM     #4 (permalink)
Setting it to never doesn't solve the problem. If the drive spins hour after hour without use, why is that better?
SMART monitoring isn't a option here.
This is a 4 1/2 year old MB with a 3 year old bios.
Ali V chipset
Also, notice that this is APM, NOT ACPI!
Old May 29th, 2003, 12:15 PM     #5 (permalink)
dunbar's Avatar
Um, no, I was referring to the drive failing angle. SMART just gave me the incentive to perform deeper tests on the drive, and many folks leave SMART disabled. Whether your mobo does or does not read SMART is irrelevant - the drive might still be dying! After all, you said:
and IIRC, ATA33 has not been current for a couple years. YMMV.
Old May 29th, 2003, 12:49 PM     #6 (permalink)
Works fine in ME on the other bootable drive!
Update...........
I have formatted and re-installed 2k in the 'standard pc' mode and enabled the NT /Legecy support. On a shutdown I see a stop message (not long enough to read it though) when it should be powering off and then it reboots.
Again this is a shutdown, not a restart.
Old May 29th, 2003, 01:26 PM     #7 (permalink)
dunbar's Avatar
And they are also powering down in ME via APM?
Old May 29th, 2003, 02:14 PM     #8 (permalink)
Yes, but, with I beleive ACPI (if that is the default). No special install here.
Old May 29th, 2003, 03:34 PM     #9 (permalink)
dunbar's Avatar
Weird. Sorry, the only thing I can suggest is maybe a patch issue.
Old May 30th, 2003, 07:21 AM     #10 (permalink)
There is a IDE patch I saw and I will try that.
Thread Tools
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Is It Just Me? (717)
Newegg WARS!!! (43)
Car Talk! (8686)
Wireless network, problem and posib.. (9)
Folderchat: The Holiday thread (156)
Best Boot Drive Imaging Software (13)
Bought an AGP "HIS Radeon HD 3.. (20)
Putting together my wish list (22)
Outlook add-in won't remove. (10)
Wireless network, problem and p.. (9)
Cisco 1710 PPTP Passthrough &am.. (1)
Laptop doesn't stay connected t.. (13)
Brother Multi-Function Machine (1)
I'm sure most of you Know this .. (4)
Olympus VN-240PC Digital Voice .. (19)
Can't print from IE7 (5)
8800GT can be run on Ultra V 35.. (0)
Computer won't start (14)
