IDE/ATA Speed Myth Dispelled
Currently Active Users: 2306
Discussions: 207,853, Posts: 2,459,457, Members: 253,353
Old January 8th, 2002, 08:56 PM   Digg it!   #1 (permalink)
Roy
Smile
A nearby thread raises the suggestion that an IDE buss runs at the pace of the lowest speed device connected.
From an Intel Tech Support discussion:
Older Ultra ATA/33 or ATA/66 drives can be easily connected to the ATA/100 interface without modifying existing software or components. The interface will automatically step down to their operating level when transferring data between the host and these older drives. (Emphasis mine ~ Roy)
Roy is offline   Reply With Quote
Old January 8th, 2002, 09:02 PM     #2 (permalink)
Ritalin Kid's Avatar
That would explain my slower HD benches... my DVDROM is at ATA33
Ritalin Kid is offline   Reply With Quote
Old January 8th, 2002, 10:13 PM     #3 (permalink)
Roy
R Kid ~ you misunderstand. Read the quote again and consider what I underlined.
Old January 8th, 2002, 10:18 PM     #4 (permalink)
KenKun's Avatar
So that means if i transfer a file from Drive C(ATA100) to drive D(ATA33) .. the transfer speed of the file will be at ATA33 maximum .. right ?..
KenKun is offline   Reply With Quote
Old January 8th, 2002, 10:22 PM     #5 (permalink)
Roy
KenKun ~ I read it to mean that the ATA100 drive talks to the Host (CPU) at 100 while the Host talks to the ATA33 drive at 33.
Old January 8th, 2002, 10:24 PM     #6 (permalink)
Canuck
FreakyOCR's Avatar
Send a message via ICQ to FreakyOCR Send a message via MSN to FreakyOCR
Right.. and if the DVD and the HD are on the same cable... It will be ata33 fromt eh dvd and ata 33 to the HDD.... right?
- Freaky
FreakyOCR is offline   Reply With Quote
Old January 8th, 2002, 10:27 PM     #7 (permalink)
Roy
FreakyOCR ~ Not right. The connection is not between the devices. It is between the Host and the devices. Re-read my reply to KenKun.
Old January 8th, 2002, 10:31 PM     #8 (permalink)
Canuck
FreakyOCR's Avatar
Does this apply to Intel chipsets exclusivly?
Old January 8th, 2002, 10:35 PM     #9 (permalink)
Roy
FreakyOCR ~ I seriously doubt it. Other chipset manufacturers would not be likely to make the mistake of failing to access the full advantage of the newer speeds.
Old January 8th, 2002, 10:37 PM     #10 (permalink)
Canuck
FreakyOCR's Avatar
If this is true.... then there *SHOULD* be no speed hit putting a DVD on the same channel as a hard drive...
But isn't it so that there is??? I will do some research to better prove my point (if it exists..)
Ask a Tech Question (free)!
Is It Just Me? (1014)
Intel Core i7 920 heat issue help p.. (19)
Woman Convicted of Drug Fraud Joins.. (5)
I need help building a computer. 40.. (33)
Best gaming GPU for $200 or less? (17)
Nvidia GeForce gt 220 problems (21)
Trouble connecting to Apartment Int.. (16)
net use command (13)
cant find drivers (8)
Wireless coverage over 3 hotel floo.. (17)
Laptop Battery issue? (10)
Zombie Cookies Privacy Lawsuit Targ.. (6)
Rate My First Computer Build (8)
new video card- screen changes to c.. (8)
Trouble connecting to Apartment Inter.. (16)
Wireless coverage over 3 hotel floors (17)
Can't open zip files in vista??? (16)
Server 2008 "read only" (0)
120G External Drive, USB 2.0: Works o.. (2)
Help Dell Latitude D610 Power Problem.. (6)
Intel Core i7 920 heat issue help ple.. (19)
new woot (5)
Which Graphic is better? (1)
On startup my monitor clicks forever .. (1)
Cavalier Internet (12)
PC turns on, gets normal post beep bu.. (0)
D drive failure? (3)
In need of Help! (1)
DVD Recorder Set-Up (3)
System fans not working (2)
good video card around 100-200 dollar.. (3)
Linux had disk space full (3)
Minidump Help (1)
I need help building a computer. 400-.. (33)
Redirect malware won't go away (6)
laptop keys broken!!1 (3)
TechIMO Copyright 2010 All Enthusiast, Inc.
