I have a Hitachi hard drive MN HDS722580VLAT20. Which jumper(will be the only drive in the system) should be used, there are multiple jumper selections on the back of the drive for maste and slave,
16 heads
15 heads
32GB clip
auto spin disable
If the drive is the only drive on a cable or the master drive on a two-drive cable, leave the jumpers as set at A-B and G-H for 16 head logical architecture. The jumpers are factory-set to Master-16 heads.
Mike
