Go Back   Tech Support Forums - TechIMO.com > TechIMO Community > Suggestion Box
We need a page dedicated to "Hot Links"
Currently Active Users: 2708
Discussions: 200,999, Posts: 2,380,013, Members: 246,369
Old April 7th, 2002, 07:30 PM     #61 (permalink)
Indispensable Member
surreal's Avatar
Send a message via ICQ to surreal Send a message via AIM to surreal Send a message via Yahoo to surreal
How to set up your own Web Server.
Free DNS Server for Dynamic IP's.
surreal is offline   Reply With Quote
Old April 14th, 2002, 05:41 PM     #62 (permalink)
Registered User
This is one great thread
ClubMed is offline   Reply With Quote
Old April 14th, 2002, 05:50 PM     #63 (permalink)
willy_ph's Avatar
Replacement for Enternet Connection software for DSL
Raspppoe
willy_ph is offline   Reply With Quote
Old April 14th, 2002, 05:51 PM     #64 (permalink)
willy_ph's Avatar
Tweak your DSL settings.
Dr. TCP
Old April 14th, 2002, 05:53 PM     #65 (permalink)
willy_ph's Avatar
Old May 8th, 2002, 07:05 PM     #66 (permalink)
fatal xception's Avatar
Send a message via Yahoo to fatal xception
^^Bump^^ for an oldie but a goodie
fatal xception is offline   Reply With Quote
Old June 6th, 2002, 10:59 PM     #67 (permalink)
Cruizing
Linux Junior
GRC systems tests and security
Drivers Guide IF you can find any drivers it may be here
VERT is offline   Reply With Quote
Old June 23rd, 2002, 10:22 AM     #68 (permalink)
puk
How 'bout Startups - full list .
Puk
puk is offline   Reply With Quote
Old September 1st, 2002, 08:47 PM     #69 (permalink)
Richard Cranium's Avatar
Thumbs up
Windows XP
To restore Windows XP Professional versions of Ntldr and Ntdetect.com on x86-based systems
1. Start Recovery Console by using the Windows XP Professional operating system CD.
Navigate to the system partition root and type the following commands from the Recovery Console prompt:
copy drive:\i386\ntldr
2. copy drive:\i386\ntdetect.com
In the preceding two commands, drive represents the letter of the CD-ROM that holds the Windows XP Professional installation files.
3. Answer the Overwrite system? (Yes/No/All): prompts by pressing Y.
4. Restart the computer.
Also;
This Windows boot disk can access a drive to work around the following boot problems:
Corrupted boot sector.
Corrupted master boot record (MBR).
Virus infections.
Missing or corrupt NTLDR or Ntdetect.com.
Incorrect Ntbootdd.sys driver.
This boot disk can also be used to boot from the shadow of a broken mirror, although you may need to change the Boot.ini file to do that.
This Windows boot disk cannot be used for the following problems:
Incorrect or corrupt device drivers that have been installed into the Windows System directory.
Boot problems that occur after the OSLOADER screen.
To work around or fix these problems, run the Emergency Repair disk, load the last known good control set, or reinstall Windows
http://support.microsoft.com/default...;en-us;Q311073
HOW TO: Edit the Boot.ini File in Windows XP
http://support.microsoft.com/defaul...b;en-us;Q289022
Computer Disk Hardware Configuration Problem
applies to:
Microsoft Windows XP 64-Bit Edition
Microsoft Windows XP Professional
Microsoft Windows XP Home Edition
http://support.microsoft.com/defaul...b;en-us;Q314477
Richard Cranium is offline   Reply With Quote
Old September 1st, 2002, 09:34 PM     #70 (permalink)
Intel's motherboard archive,
http://www.intel.com/support/motherb...op/archive.htm
Intel motherboard support page
How to ID a board, support issues, etc
http://www.intel.com/support/motherb...herbd_support&
Is It Just Me? (3111)
‘Rogue’ or ‘Rouge’? (10)
Foxconn Blackops x48 MoBo (5)
Nvidia GTX 260 problem (14)
Delete an OS (18)
Laptop with wireless problem. (13)
add ram to existing (4)
Delete an OS (18)
Print spooler problem (17)
Q9650 vs. Q9550 (2)
soundmon.exe (8)
Jedi Academy Problem (3)
