Go Back   Tech Support Forums - TechIMO.com > PC Hardware and Tech > Tech News Discussion
Join TechIMO for Free!
Thread Tools
Currently Active Users: 2029
Discussions: 186,719, Posts: 2,228,248, Members: 230,375
Old August 19th, 2008, 04:21 PM   Digg it!   #1 (permalink)
Anime Otaku
RobRich's Avatar
Gigabyte EP45-Extreme Motherboard Review
The Gigabyte EP-45 Extreme motherboard uses the new Intel P45 chipset, which is considered a “mainstream” chipset by Intel. How will this chipset compare to the wildly popular X48 chipset? Will the overclocking be better on the P45 chipset? Paired up with the Northbridge heatsink, will there be anything that can stop the Gigabyte EP-45 Extreme motherboard?
Source: Overclockers Club
Robert Richmond | TechIMO Editor-in-Chief
Infinite perceptions. One reality.
FanFiction.Net - Unleash your imagination.
RobRich is offline   Reply With Quote
FREE instant scan
Old August 25th, 2008, 09:40 PM     #2 (permalink)
Wasted's Avatar
It's making me want to get a loan
Shame about the SATA ports location. Really would think if you buy that board your going to have a card that covers those slots. No point in them being there..
AMD X2 4800+ on an ASRock 939N68PV-GLAN
ASUS Extreme 8800 GT 512
2Gb OCZ Gold XTC PC-4000
Wasted is offline   Reply With Quote
Old August 25th, 2008, 10:02 PM     #3 (permalink)
nemowolf's Avatar
Making the same point as I did in the previous thread. The SATA ports are in the same spot and appear as unlikely to cause problems as the other P45 mobo. They even had the forsight to put the SATA on a stack to make sure that the cabling go out from the mobo instead of up into a potential long board GPU.
Old August 25th, 2008, 11:06 PM     #4 (permalink)
Wasted's Avatar
Well in the reviwers summation he said they where an issue, got to admit i didn't look that closely at the pictures, i was too busy being in awe of the north bridge heatsink
Old August 26th, 2008, 11:54 AM     #5 (permalink)
Wasted's Avatar
Had a closer look, assuming the GPU slot is the blue one the length wouldn't effect the first 2 SATA as they've been angled to point away from the slot, very cool idea. I can see if you where using a card that effectivley takes up two slots in width it would obscure the next pair of SATA ports down.. ..or that's what it looks like to me.
It's clearer in this photo http://pics.computerbase.de/2/1/4/6/6/2.jpg
Old August 26th, 2008, 02:00 PM     #6 (permalink)
nemowolf's Avatar
That I will totally agree with. Double depth cards are a pain in general, since mobo manufacturers can't count on everyone having one for their design its not bad. I can't think of too many people who run six HD's though, so losing two and only having access to four wouldnt be bad. This does make me wonder if changing the design to have all six ports be stacked like the first two would be more expensive or not. They potentially should have thought of that. Could be revolutionary!!!
Old August 27th, 2008, 06:58 PM     #7 (permalink)
Wasted's Avatar
In general or for most of us 6 HD's is total overkill but if your spending uber top of the line Mainboards like this you're probably saving a bit for 4 raptors for RAID 1 on your system and games drive and 2 more for your backup and storage not to mention £400 on your GPU with aftermarket cooler that will take up 2 slots
It is a top place to put your SATA and pointing them all the way, probably straight at 2 of your HD's and cable tucked away between then run up the back at the side to pick up the rest.
Can't see the component being much more expensive all your doing is turning the pins that link to the board 90 degrees and a bit of sxtra plastic to cover them. Still if their only 1 pence more expensive, i doubt they'll be on many bottom of the line boards
It such an obvious oversight it makes me wonder if they missed anything else more important..
Thread Tools
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
GigaByte GA-EP45-DS3L Motherboard Review RobRich Tech News Discussion 3 August 25th, 2008 09:39 PM
Gigabyte EP45-DQ6 Motherboard Review RobRich Tech News Discussion 0 August 11th, 2008 01:36 PM
Asus Striker II Extreme Motherboard Review RobRich Tech News Discussion 0 June 9th, 2008 03:36 PM
Gigabyte EP45-DS4 Intel P45 Motherboard Preview RobRich Tech News Discussion 0 May 7th, 2008 05:05 PM
Asus Striker II Extreme Motherboard Review RobRich Tech News Discussion 0 April 30th, 2008 09:15 PM
Is It Just Me? (738)
E5200 15.2GHZ?? (8)
Newegg WARS!!! (46)
I'm sure most of you Know this but!.. (5)
Folderchat: The Holiday thread (156)
Bought an AGP "HIS Radeon HD 3.. (20)
Cat5e Patch length limit help pleas.. (10)
Best Boot Drive Imaging Software (13)
Wireless network, problem and posib.. (9)
Turn on WoW and computer shuts .. (14)
Dual Boot Option Not Visible (0)
what is 21435 kbps? 2.1mb? (1)
LCD monitor sizes and wide scre.. (1)
Compatible Mobo/CPU mystery (0)
Cat5e Patch length limit help p.. (10)
Best graphics card for around $.. (4)
Pen drive problem. (2)
TRUE 1080p LCD picture (20)
