harddrive problem  | | |
February 29th, 2004, 05:45 AM
| harddrive problem
I'll try to lay this out the best I can, because I have no idea what's going on.
I was using the program fraps ( www.fraps.com) to capture video for some games, and one time when I was capturing some videdo of halflife I ran into a problem.. I cant delete one of the videos I created. I cant move it , I cant rename it, I cant delete it, because it's "in use by another program or process etc blah blah blah." Restarting doesnt fix this.
Since the file is rather large (around 4 gigs I would say) I decided I would try running chkdsk /f to see if I could fix a problem with the disk and then try deleting it. Nope. No go.
Chkdsk /f can't be run because the volume is in use by another process.
I can't format.
I tried installing windows... I got so far and then it gave me an error, something like s_____.sys is missing, set up failed, blah blah blah.
One of the more recent times I've booted I recieved a missing hal.dll error... I think it was hal.dll, but I'm not 100% sure.
What is wrong with my drive? Is there a way to wipe it clean? Can this be fixed?
PS:
I'm running a pentium 4 3.0 ghz processor, 1 gig of DDR, 80 gig seagate harddrive, geforce fx 5200, Windows Xp... I can't think of anything else I'd need to include for this.
I've run Norton AV too and it found nothing, I also tried disk clean up.
February 29th, 2004, 06:29 AM
So you tried formatting from inside windows? I know for a fact that you can not format the c: drive b/c the OS is on that drive and is using the C: drive so formatting is impossible. The easiest way to check the HDD would be to take it out and put slave it into another computer. If there is nothing wrong you should be able to read all of the files. If the HDD is bad then you wont. If you slave the HDD you can also rest assured that the HDD will no longer be used as a primary so you should no longer get the "in use by another program" message. From there you should be able to delete that one file and/or format the drive. |
February 29th, 2004, 06:32 AM
| | It's full of stars ¬_¬;
try a winme or win98 emergergency boot disk. if it can't delete the file, then fdisk /mbr the drive. restart, run fdisk again to check the partition, you may have to delete it and make a new primary dos partition. restart again and format.
edit: didn't realise you were trying to format from inside windows. in that case, boot from your xp cd to the recovery console and you should be able to delete the file.
No man's life, liberty, or property are safe while the legislature is in session. --Mark Twain (1866)
February 29th, 2004, 08:39 AM
These other posts should resolve your hdd prob. In the future if you can't delete a program go to task manager > processes and see if it is running, if it is hilight it and click end process, you should be able to delete it at that point |
February 29th, 2004, 02:55 PM
| Quote: |
| Well, the only other computer I can do that in does not use the same connecting cables... my computer is about a month old and so it is more high tech than my old one.
I ran chkdsk /f from the emergency console, and that still didn't fix my problem, still can't delete the file.
I got windows set up to run, but it doesn't have the option to format the drive and perform a fresh installation... Quote: |
| I went through and stopped just about every process I could, and still no go. Quote: |
| I still have yet to try this, I'll try it right now |
February 29th, 2004, 02:58 PM
| | Now in the nicer ghetto
try restarting in safe mode and deleting the file...
I don't like signatures.
February 29th, 2004, 03:00 PM
I've also tried formating from the recovery console.... It warns me that all data will be lost, and asks if I want to proceed. After I say yes, it doesn't seem to do anything. |
February 29th, 2004, 03:03 PM
I'll try restarting in safe
February 29th, 2004, 03:07 PM
someone can correct me, but i think it is hitting f8 during start up, then click safe mode. a simple google can explain it all if needed. |
February 29th, 2004, 03:10 PM
| | F@H Cheerleader
Why do I run F@H ? Because its one way I might actually make a difference in somebody's life. http://folding.stanford.edu/ |
