GA-7N400PRO2 - AthlonXP Mobo - CD/network/Restart Issue
Currently Active Users: 1918
Discussions: 200,921, Posts: 2,379,087, Members: 246,289
Old March 29th, 2004, 02:21 AM   Digg it!   #1 (permalink)
I have built a computer based on the Gigabyte GA-7N400PRO2 Mobo.
I have also established an ADSL line with Netgear modem.
The mobo has two DVD drives and onboard GLAN.
When the Ethernet cable is plugged in, if I then insert a CD into either drive it causes WinXP Home to launch a fault and restart.
If I leave the CD in the drive, as it reboots into Windows it detects something and then restarts.
If I unplug the Ethernet, the computer works fine...
Now, has anyone experienced this problem before? And are there any solutions or ideas?
Thx
Rohan
roley is offline   Reply With Quote
Old March 29th, 2004, 02:29 AM     #2 (permalink)
I have tried uninstalling the Realtek LAN. And replaced Nvidia drivers with microsoft drivers, but it did not fix the problem.
To be tidy, I have the cables wrapped up in a PET wrap from Cableorganizer...there are 3 cables in one of these tubes: CAT, USB and System Power Cable.
I have been inside the case and replugged all the IDE and power connectors and that did not work...
Rohan
Old March 30th, 2004, 03:32 AM     #3 (permalink)
I have tried using a different CAT5.......still problem
I have tried drivers........still a problem
I have reflashed BIOS.......still problem
Next, I will try changing the ADSL modem from CAT5 to USB connection...that should work out...
If that does not work...then it looks like a new modem is required...maybe Dynalink or something.
rohan
Old March 30th, 2004, 03:57 AM     #4 (permalink)
The_Shooter's Avatar
You said that you put the ethernet card in and it caused your computer to crash? If thats the case, you have a defective card. Get a new one. If you CAN connect thru the USB, then it is the card, otherwise, I would see if you can log into the netgear modem/router? Assuming it is a router.
Intel Q6600, Intel DG965WH
6GB Corsair 800 DDR2, 4x 500GB HD, EVGA 260 GTX SSC, OCZ 700W PSU, 22" Dell LCD
The_Shooter is offline   Reply With Quote
Old March 30th, 2004, 05:26 AM     #5 (permalink)
The gig LAN is on-board/integrated...
But I have considered that it may be damaged in some way.
However, I built it for a customer and when it was connected to my workshop LAN it functioned well.
What are your thoughts?
Rohan
Old March 30th, 2004, 10:41 PM     #6 (permalink)
I have found SOLUTION:
I tested the connection with a Dynalink RTA100 and that did not fix the CD/restart issue...or the frozen "windows is shutting down screen".
I then tried Registry Mechanic in case there was a registry error...still no fix.
I then decided to uninstall one at a time the networking components in the network connection properties.
None of the other components, excluding TCP/IP which couldn't be uninstalled, resulted in a fix.
However, the removal of Client for Windows Networks fixed the problem.
I still manage to get ADSL connectivity etc without this service installed (Windows XP Home) but it solves the two issues I was having before.
This may have something to do with the fact that I connected this computer into my domain's switch to get ADSL for updates etc prior to delivery. But I cannot be sure of what might have happened there, if anything.
Hopefully this helps someone in the future.
Rohan
Is It Just Me? (2854)
Obama the Muslim (13)
radeon x850xt platinum & shader 3 (1)
Virus Doctor Popup? (1)
SIS 740 and Widescreen (8)
PSP Go bought in Japan (0)
