Dell Latitude Monitor Problem.
Currently Active Users: 1611
Discussions: 200,925, Posts: 2,379,128, Members: 246,291
Old April 24th, 2004, 06:11 PM   Digg it!   #1 (permalink)
mar122999's Avatar
I have a question. I just purchased an LCD screen for my Dell CPi laptop. It came with the whole casing and internal inverter. The size of the screen was the same and it also said CPi on the outside. The only problem is that my laptop will not boot whenver I hit the power button. The battery indicator light on the laptop just blinks red. I opened the LCD and saw that the LCD inverter was different that mine (it mounts underneath the LCD screen. Mine mounts on the side). I put mine back on and it fired up with no problem. I believe it may be some power compatibility issue with the laptop screen.
Also, I will tell you what is wrong with my LCD. Maybe one of you could have a solution. The screen is missing about 1/4 of the way to the right vertically (1/4 of the screen is vertically black). I have tried moving, replugging the flex wires, checking for loose connections every, and tapping on the outside.
mar122999 is offline   Reply With Quote
Is It Just Me? (2865)
Obama the Muslim (14)
Have you switched yet? (84)
Optical Audio A-B Switch (1)
Fire in DVD (0)
Virus Doctor Popup? (1)
SIS 740 and Widescreen (8)
