Tech Support Forums - TechIMO.com
Tech Support Forums - TechIMO.com (http://www.techimo.com/forum/)
-   Technical Support (http://www.techimo.com/forum/technical-support/)
-   -   Laser Needs Second 'Command' to Print (http://www.techimo.com/forum/technical-support/108936-laser-needs-second-command-print.html)
MegalosSkylaki May 1st, 2004 11:05 AM
Brother HL-1440 is funky.
Lights are unreliable as diagnostics because the flash a lot. Can live with.
But when we try to print, often nothing happens except maybe some print-like noise. Then we do Print command Again, and it prints.
Darn Nuisance having to go throgh two commands for one sheet !
Anybody know what's up ?
DOOOG
Ruler2112 May 3rd, 2004 01:48 AM
Also, is it with every application you try to print from?
If it's only when waking up, you can change the sleep time in the driver settings to 0 to force it to stay awake, or up to 99 minutes to delay it going to sleep.
I've put about a dozen of these printers in use at my place of employment and have never experieced anything like this. Have you DLed and installed the latest drivers for your OS? Speaking of OS, which one are you using?
TechIMO™ Copyright 2007 All Enthusiast, Inc.
