Enticing Problem ;)
Currently Active Users: 1728
Discussions: 200,924, Posts: 2,379,121, Members: 246,290
Old May 6th, 2004, 09:16 AM   Digg it!   #1 (permalink)
Send a message via ICQ to c6ke
Cool
Enticing Problem ;)
Allright First of all the necessary info:
Main: Asus A7V8X -> VIA KT 400
CPU: AMD Athlon Thunderbird 1,7 -> 3,2 Overclocked
Ram: 512 Infineon DDR
Graphics: XFX (Pine) GeForce FX 5700
Disks: 4 (2 SCSI 2 IDE -> Windows and Games are on IDE (same disk))
OS: Windoze XP Pro
DirX: 9.0 b
Problem:
My system worked perfectly well - everything (except the nvidia nview). As I needed the nview for a presentation I formatted the main boot c: in order to reinstall everything. Now that worked all well and I can work with that PC now. The problem is that I just can't play or view ANY DirectX Application. The following thing occurs:
I open a game and play it about 5 Minutes. Then It makes a crack in the sound - The legendary soundloop starts and I just can't do a thing anymore. The whole system is stuck (I guess everyone knows what I'm talking about).
Here is what I tried:
Now I had that problem once before with another computer... There I just forgot to install the VIA AGP Driver. This time I already installed it. So I see no real reason.
- I gave the graphics adapter and CPU more Volts... No work (graphics up to 1.7 and cpu up to 1.7 Vcore)
- I put the CPU back to its original Frequence... No work (attention: THE CPU DEFINITELY WORKS WITH 3.2!!! Don't bug me with that - I made several burn in tests before with that CPU and that frequency... IT WORKS - OK? !!!)
- I reinstalled the actual 4 in 1 Service Driver for VIA Chipsets
- I even formatted the system anew... no work...
Now has anybody got an idea what could be the reason??? I definitely see none and really need your help (I'm one of these LAN Party freaks who enjoys playing his PCs for a long time )
This is really a bad thing to fix as my system's wlking on my nerves doing this.... PLS HELP!
Do you also hear those voices?
c6ke is offline   Reply With Quote
Old May 6th, 2004, 10:14 AM     #2 (permalink)
Send a message via AIM to Shabow
What is your bus frequency?
Shabow is offline   Reply With Quote
Old May 6th, 2004, 10:36 AM     #3 (permalink)
I used to have the exact same problem a couple years back with a slot A Tekram board running WinME.
I never really found the exact cause etc...and I posted a few questions about it.
Seems I ran DrWatson and it mentioned a possible problem with the modem...or somehow I came to the idea that it was a modem driver......so I changed to a different modem driver and the problem finally stopped.....go figure.
JP
Old May 8th, 2004, 07:15 AM     #4 (permalink)
My Bus freq. is 167... It's the last one supported by my PCI cards - as it is 167/33... if I go to 168/34 it's no work anymore (PCI-Bus)
Dunno witch card it is that stops me doing that
Well any ideas then?
Is It Just Me? (2863)
Obama the Muslim (14)
Have you switched yet? (84)
Optical Audio A-B Switch (1)
Fire in DVD (0)
Virus Doctor Popup? (1)
SIS 740 and Widescreen (8)
