Results 1 to 8 of 8
    May 2004
    2
    Laptop Power Problems
    I have Recently Purchased A Dell Latitude CPx Model No: PPx. It has been Working fine for the last month but once when i was using it i found out that the laptop was not able to run off the power cord any more. It can run off battery power but it can't recharge or run off the cord. I tried my friends cord and my cord worked on his laptop but his did not work on mine. Does anyone know whats going on with my laptop?
    Senior Member mike_sanfil's Avatar
    Sep 2003
    986
    does it have a warrenty?? sounds like your laptop is defective
    Member shaundolphin's Avatar
    May 2004
    England (Midlands)
    128
    take it back where you purchased it and let the store have the headache i think dude
    May 2004
    2
    well i cant really return it for i bought it at a computer show can it only came with a 30 day warenty... so are you saying that the laptop is busted...
    Ultimate Member AzKidd69's Avatar
    Queen Creek, AZ
    1,480
    sounds liek what happened to my laptop abput 6 months ago.. the power connector on the mobo ( the one that the power adapter plugs into ) was fried...... there are ways to fix ust the plug.. BUT most places will just want to replace the whole mobo.. see if you can find a true electronics repair shop that is competent enough to change just the plug on the mobo. I would reccomend letting said repair shop first verify this is truly the problem first tho.
    also you can prolly look on ebay for a replacement mobo for that lappy too
    Living the dream The Real Bingo's Avatar
    Aug 2003
    Afghanistan
    22,704
    Yep, sounds like the same thing that happened to mine. The connector where the cord goes to the computer is fried, like AzKidd69 said. If you know how to get in there, and know how to solder, then that would be the solution to the problem. It is such a pain to get in there, though, you are better off paying someone to do it. Also, regarding what happened to me, my father went in there but the solder wouldn't take. So just be forewarned.
    May 2004
    similiar problem
    I have a Dell Latitude cpi and it works fine with just one problem. It will not power on by itself without it being plugged in. It is almost as if the battery doesn't have enough power to start it even though the battery lasts an hour and a half. This is very strange, please help!
    Jan 2003
    Connecticut, USA
    816
    welcome to techimo, fading!
    are you sure your battery lasts an hour and a half? it could be that you have a cd in the drive, and accessing it during boot might be draining the battery faster than you think. also check your boot order (boot hdd first) and eliminate as many programs starting when windoze starts as possible to maximize cpu time on battery.
    ~Branson
    I'd try a new cord first, then contact the manufacturer or reseller with an inquiry.
    I'm an Eagle Scout! (1997)
  1. Please HELP
    By irret_irret in forum Technical Support
    Last Post: January 14th, 2004, 09:31 PM
  2. IBM TP 600E power problem
    By burhany in forum Mobile Computing
    Last Post: January 6th, 2004, 11:17 AM
  3. clevo 5620
    By gonsito in forum Mobile Computing
    Last Post: July 8th, 2003, 10:55 AM
  4. Thinkpad battery light always on
    By Zumndad in forum Technical Support
    Last Post: November 8th, 2002, 07:34 PM
