Join TechIMO for Free!
Thread Tools
Currently Active Users: 1996
Discussions: 186,720, Posts: 2,228,263, Members: 230,375
Old May 24th, 2004, 01:24 PM   Digg it!   #1 (permalink)
power supply
i have a comp
now the power supply seems to be not working and fan is off.
i have opened the cover of the comp but there seems so many wires and cables. how to fix this probelm guys plz help me. i am ameture.
thanks
indi is offline   Reply With Quote
FREE instant scan
Old May 24th, 2004, 01:47 PM     #2 (permalink)
paul9's Avatar
Send a message via MSN to paul9 Send a message via Yahoo to paul9
some general tips.
if there is a fuse in your mains plug try changing that. if that doesn't work, then change the power supply for a new one. make a simple diagram to let you know where the wires are to go back to. make sure the mains plug is taken out of the wall socket before you try to change anything. be careful as the edges of the metal pieces inside your pc are often sharp, and you can easily cut youself.
paul9 is offline   Reply With Quote
Old May 24th, 2004, 01:58 PM     #3 (permalink)
it is a little difficult because it could be the power supply...or the motherboard...or the cpu.
One thing you can do to try to narrow it down is.....
unplug the power chord from the back of the power supply.
unplug the biggest connector from the power supply to the motherboard..it is called the atx connector...looks like this from the bottom http://lib1.store.vip.sc5.yahoo.com/...sfig2large.jpg
anyway, it is the biggest one coming from the power supply and it goes staright to the motherboard....what you do is unplug it....then you take a paper clip and bend it into a "u" shape"....then you plug one end of it into the hole on the connector where the green wire is at....then you plug the other end into any of the holes where a black wire is at.
Then you plug in the power chord to the back of the supply and see if it powers on...it if dies...then probably the motherboard or cpu is bad...but the supply is ok.
If the power supply DOESNT turn on then...what you need to do is disconnect all the other wires from the supply that are going to the hard drive, cd roms etc etc....disconnect all of them except maybe one going to a fan or one hard drive....then try it again and see if the power supply comes on.....if it comes on then, then it tells you that one of those components is bad and is loading down the power supply to where it wont come on.
Old May 24th, 2004, 02:00 PM     #4 (permalink)
Steeler Fan
jman01pa's Avatar
If you have checked all your connections and power sources (ie power strip, outlet, etc...) then chances are your power supply is dead and needs replaced. What brand / model is your pc or is it a no name box?
jman01pa is offline   Reply With Quote
Old May 24th, 2004, 02:03 PM     #5 (permalink)
actually on an atx supply it should be pretty easy to see where stuff goes...the atx connector can only go in one place and only in one direction....the other 4 wire connectors can go to any conenction..in other words they are the same and can go to cdroms or hard drives etc etc..so its not necessary to put them exactly back where they came from....you might want to pay attention to the little small floppy power connector...because unless you know where it goes it may be hard to find it, lol...cuz its small.
But I just say all this to let you know that you dont have to put the 4 wire conenctors exactly back where they came from...the conenctors to the hard drive, or cdroms etc are interchangeable.
Old May 24th, 2004, 02:50 PM     #6 (permalink)
paul9's Avatar
true enough jp, assuming it is not an at supply, plus the diagram can give a confidence boost to an amateur, and lead to good practices if the amateur decides to do other minor pc repairs/upgrades.
Old May 26th, 2004, 10:14 AM     #7 (permalink)
comp specification
it has DVE swithing power supply model DSP 145 AP, input 100-125 V,
5A, 3 A 60 HZ and 5v, 12 v -5 and -12 v and 20 A 7.5 A. 0.5 A 0.5 A with 200 w out put.
The comp' specification is :
133 MHZ Intel Pentium Processor,
1.2 [1,200 MB] GB HD drive ,
16 MB RAM,
PCI local bus video
PCI local bus IDE hard drive interface,
speficied 6 x speed rom drive[ but inside the comp is 8x speed CD drive fixed]
1 MB video memory
pre installed MS Windows 95
28,000 bps modem, 14.000 fax and mouse and microphone, 16 bit stereo
etc
i use it as wiritng my script/notes and few other small things.
any sufggestions nOw
thanks for the help
indi
Old May 26th, 2004, 12:18 PM     #8 (permalink)
Send a message via AIM to MadMan2k Send a message via MSN to MadMan2k
Hopefully you read the above suggestions, and tried them...
MadMan2k is offline   Reply With Quote
Old May 27th, 2004, 10:18 AM     #9 (permalink)
the power supply has PS1 and PS2 connected to the mother borad. i have taken both out. there is no' green cord' in there. they have blue and red, organe and black.what to do now...plz help
Old May 27th, 2004, 10:29 AM     #10 (permalink)
Banned
sounds like an A T power connecter. fit them onto the board so that there r black wires on 1 plug next to black wires on the second plug. did that make any sence at all??? or is 1 of thouse connectors a 4 pin and the other like a 20 pin? if so they will only go in 1 way jus line em up
Zedicus is offline   Reply With Quote
Thread Tools
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Power Supply Gaby Technical Support 3 March 15th, 2004 11:51 AM
Waiting for my vid card maniac_113 Graphics Cards and Displays 2 December 29th, 2003 10:29 PM
FX 5200 Unable to Bootup mattspew Graphics Cards and Displays 17 July 28th, 2003 12:32 AM
Help build an AMD for under $500 Mr. NoOne Technical Support 26 May 25th, 2003 04:05 AM
Power Supply Question azwelkers General Tech Discussion 4 October 29th, 2002 09:52 PM
Is It Just Me? (740)
E5200 15.2GHZ?? (9)
Newegg WARS!!! (48)
Car Talk! (8693)
I'm sure most of you Know this but!.. (5)
Folderchat: The Holiday thread (157)
Bought an AGP "HIS Radeon HD 3.. (20)
Best Boot Drive Imaging Software (14)
Wireless network, problem and posib.. (10)
Wireless network, problem and p.. (10)
what is 21435 kbps? 2.1mb? (2)
What graphics card range for q9.. (7)
this Virus never see Before (0)
E5200 15.2GHZ?? (9)
Best Boot Drive Imaging Softwar.. (14)
Turn on WoW and computer shuts .. (14)
Dual Boot Option Not Visible (0)
