finally doing first build
Currently Active Users: 1812
Discussions: 200,505, Posts: 2,374,369, Members: 245,828
Old June 25th, 2004, 07:43 PM   Digg it!   #1 (permalink)
i can figure out most of the build i just have one question. the cpu i bought is separate from the heatsink/fan. i (stupidly) bought some cheap thermal compound just in case the combo didnt come with compound (ultra silver thermal compound 1.0g). i dont know how good of a compound it is...but hopefully they sent something with the combo.
what kind of things do i have to be cautious of when putting the heatsink onto the cpu? im assuming it goes on before attatching to board.
thanks in advance
engineuity is offline   Reply With Quote
Old June 25th, 2004, 07:45 PM     #2 (permalink)
The Real Bingo's Avatar
You have to put the chip into the board before you hook the heatsink onto it.
Just spread the gook on nice and good. A thin layer so you don't have any runoff, and make sure its evenly spread. Chances are you will have to finagle the heatsink for a while before you get it on. Don't lose patience, though.
Good luck.
The Real Bingo is online now   Reply With Quote
Old June 25th, 2004, 07:51 PM     #3 (permalink)
thanks ill be doing it in a few days
Old June 25th, 2004, 07:59 PM     #4 (permalink)
I like to put the cpu on the motherboard..then put the motherboard in the case etc..then put the heatsink on last.
you dont need much thermal compound....just one small "dot"...and dont try to spread it around...when you put the heatsink on the pressure will spread it around.....
usually you use a flat blade screwdriver to get a little pressure on the mounting tabs...but dont overdo it...and dont let the screwdriver slip and poke a whole in the board!
it is possible to get a heatsink on backwards..but if you look at the shape of the socket on the board it makes it easier....watch the "heatsink installation" video and notice what they say about the "step" on the bottom of the heatsink...that is how you see if its backwards...the step matches the "overhang" on the socket...
some nice videos here..showing how its done.... http://www.amd.com/us-en/Processors/...5E6678,00.html (ignore it when they recommend a thermal pad over thermal paste, lol)
And give it a close look over before you boot....if u get the heatsink on there all cockeyed..to where it isnt even flush on the cpu....the cpu will have a short but eventful life (a second or two?)
JP
now if you want to be highly scientific about it....you can check out Arctic Silver's website for their in depth instructions on thermal compund http://www.arcticsilver.com/arctic_s...structions.htm
I break half those rules and there is conflicting advice on different sites....I personally have never tried to 'spread' any compound....I usually put a small "dot" or "mound" on the center of the cpu..then I put the heatsink on it and the heatsink pressure spreads it fine and dandy.....now on things like older celerons where the core of the cpu is much bigger there might be some spreading needed
Old June 25th, 2004, 08:05 PM     #5 (permalink)
It's full of stars ¬_¬;
paul9's Avatar
Send a message via MSN to paul9 Send a message via Yahoo to paul9
use a credit card or similar to protect your mobo from damage if the screwdriver slips. a little tip i picked up from these wonderful forums i usually use a thin, narrow bladed slot driver, which has a bend about an inch from the tip, just a small 20 degree or so angle which helps a great deal.
paul9 is offline   Reply With Quote
home built pc disappointment badhrt Technical Support 31 April 25th, 2004 10:20 AM
computers store bought vs build own missyusa General Tech Discussion 25 February 26th, 2004 04:48 AM
mac vs. pc (building) CraigK General Tech Discussion 14 October 5th, 2003 12:16 AM
Heat = autoshutdown joker_927 Processors, Memory, and Overclocking 9 August 18th, 2003 01:50 PM
Proof of Ghost Cruez IMO Community 70 January 15th, 2002 11:07 AM
Is It Just Me? (1628)
FT HOOD attack: 7 killed 12 injured (64)
HELP!!! What do you think of this s.. (14)
My 1st pc build (40)
Aero in Vista (7)
How to Ship a PC (16)
slaving laptop drive (7)
Need Assistance Overclocking and Ra.. (14)
2009 Build (4)
Review My Build (2)
HELP!!! What do you think of this sys.. (14)
FAT32 to NTFS file system in Win2kpro (1)
hard drive problem (2)
Hard Drive test program (2)
New Linksys Routers (2)
Motherboards and my curse... (24)
Mic won't work. (2)
Weird Vista Internet Issue (2)
