Packard Bell Display Problem!
Currently Active Users: 1917
Discussions: 200,921, Posts: 2,379,087, Members: 246,289
Old July 11th, 2004, 05:48 PM   Digg it!   #1 (permalink)
I don't know what has happened to my computer.. it is a packard bell, about 5 years old. Windows 98 (build 4.10.1998).
Here's some info
Packard Bell NEC PLT SUPR 1961
Board: Intel Corporation AL440LX
300 megahertz Intel Pentium II
64 Megabytes Installed Memory
Here's my problem.. I can't get my display to change from 640x480 16 Color.. i want it to be 720x576 256 Colors.. it won't let me change it.. i've tried everything.. shut down my computer a number of times, and the settings just won't stay. I've tried to go into advanced settings and change the monitor but that hasn't helped either.
S3 Inc. ViRGE GX2 [Display adapter]
Packard Bell 1024 [Monitor]
Packard Bell 1428ME [Monitor]
Packard Bell PnP 7480 [Monitor]
Please reply with ANY help..
xthe12onex is offline   Reply With Quote
Old July 11th, 2004, 06:33 PM     #2 (permalink)
It's the cheese guy! ¬_¬;
paul9's Avatar
Send a message via MSN to paul9 Send a message via Yahoo to paul9
have you tried setting the refresh rate from default to optimal or vice versa? does it change to these settings you are trying, but not keep them? will it do 800x640 which is a more 'standard' resolution? and does it show s3 virge on packard bell 1024 or s3 virge on default monitor in the settings as your primary display? make sure it is not on default monitor, if you can.
paul9 is offline   Reply With Quote
Old July 11th, 2004, 06:42 PM     #3 (permalink)
yeah.. i've changed the refresh rate..
and it will change the settings from 640x480 but NOT STAY
I'm not sure if it's set as default monitor, how do i change that?
It says:
Display:
Packard Bell PnP 7480 on S3 Inc. ViRGE GX2
Old July 11th, 2004, 07:08 PM     #4 (permalink)
paul9's Avatar
that one looks ok, as long as that is the actual monitor type you have. not too sure how to proceed, apart from a driver update/reinstall, but it seems more likely a windows annoyance than a driver at the moment. you could maybe try telling it to apply the settings after a restart instead of without restarting.
Old July 11th, 2004, 07:23 PM     #5 (permalink)
tried that too.. i set it to apply after restart, restarting before applying, and to apply without restarting.. the setting just goes right back..
also when i click the display icon on my taskbar.. it has a check beside the 640x480 16 Color and there's not other choices.. I Tried to take the check off, but it won't let me
Old July 11th, 2004, 07:31 PM     #6 (permalink)
paul9's Avatar
16 colour? sorry, i assumed 16 bit colour. either you are in safe mode, or it is new driver time. also try a direct x 7 install if you can find it, or reinstall your current version of direct x
Old July 11th, 2004, 08:02 PM     #7 (permalink)
no.. 16 color.. not 16 Bit..
I'm not in safe mode.. though i have tried going into safe mode to see if i could fix it but it didn't work. It may be time for a new driver.. also, i'm installing directx 9..
Old July 11th, 2004, 08:12 PM     #8 (permalink)
paul9's Avatar
dx9 might be pushing it a bit for the cpu and memory you have. at the very least, you should consider upping the memory to 256m. it wil fly like a new machine. that and a largish fast hard drive will boost the performance quite a bit. if the new drivers don't work, then it may be time to chant the microsoft mantra: reformat and reinstall.
Old July 11th, 2004, 08:27 PM     #9 (permalink)
i'll try to find dx7 then and download it and see if it helps.. if that doesn't help what do you reccomend?
Old July 11th, 2004, 08:34 PM     #10 (permalink)
just passin thru
Sweeper's Avatar
Sounds like a driver issue. Try either reinstalling the drivers you were using and or install the latest for that video adapter.
P4 3.2 'E', 4GB DDR400, XFX Geforce 6600GT 256MB AGP, MSI 865PE Neo2-P, WD S-ATA II 500GB HDD, Win. Vista
Sweeper is offline   Reply With Quote
Packard Bell info Wolfman11511 Technical Support 9 November 11th, 2003 02:38 PM
Worst comp ever!!! Can ya beat me? Warheart666 IMO Community 28 October 27th, 2003 03:41 PM
cpu compatability daman46 Technical Support 3 May 31st, 2003 06:17 PM
The WalMart disappearing computer cooter007 General Discussion and Buyer Guidance 21 February 16th, 2003 12:52 PM
PC NO LONGER DEAD fox06 Technical Support 15 January 30th, 2002 09:59 AM
Is It Just Me? (2854)
Obama the Muslim (13)
radeon x850xt platinum & shader 3 (1)
Virus Doctor Popup? (1)
SIS 740 and Widescreen (8)
PSP Go bought in Japan (0)
