soyo k7vem-pro reboot issue  | |
August 11th, 2004, 04:10 PM
have a soyo motherboard k7vem-pro with duron 1300 and 256 megs pc 133 ram
started having a problem while in games would just suddenly reboot now when you go to start the computer the moment you turn it on you will hear a clicking sound coming from the motherboard ( i know its from the m/b cause i unplugged all devices ) and as it clicks it reboots i can keep hitting reset and every now and then it will try to boot but as soon as it tries to go from the windows 98 screen to desktop it reboots have reformatted three times same deal, have flashed bios same deal, tried other power supplies same problem any ideas or suggestions???? |
August 11th, 2004, 08:37 PM
ferqusonjef
Both hardware and software can cause rebooting problems.
I suggest you run a virus check to see whether you've been hit. Perhaps you should also to re-install your game, the one you were playing when the reboot suddenly occurred.
As for hardware, you've more or less eliminated the power supply as the cause of the problem. But check to see whether your power supply connections are secure.
CPU, ram and motherboard are the next three items you should be looking at. Take a look at your motherboard. Do you notice any shorts, any burning or anything out of the ordinary at the CPU side. Check also for hairline cracks, if any.
Oh, BTW, welcome to Techimo.
Michael Chiew |
August 11th, 2004, 09:34 PM
| im thinking its the motherboard but i cant figure out why its making the clicking noi
im thinking its the motherboard but i cant figure out why its making the clicking noise, have disconnected all ide cables and power cables to all devices and it still makes a clicking noise.. as far as the game it does it when ever you were playing anything now it just wont boot, have reformatted and tried various things, im at a loss |
August 11th, 2004, 10:44 PM
I suspect the motherboard, too, but cannot discount CPU or ram.
Are all your connections secure. Is the motherboard grounded, all screws and stand-offs securely fastened.
Can you pinpoint exactly where the noise is coming.
Michael Chiew |
August 12th, 2004, 09:00 PM
i have noticed that now when i try to reload windows everytime it gets to the part of loading windows help it reboots. i am mystified............. same spot everytime... |
August 13th, 2004, 12:00 AM
fergusonjef
Can you be a little more precise about what you mean by "when I try to reload windows everytime it gets to the part of loading windows help it reboots."
Exactly what do you mean by "reloading Windows" and "getting to the part of loading Windows help."
Michael Chiew |
Similar Threads | | Thread | Thread Starter | Forum | Replies | Last Post | | Help me overclock, having problems | BustedAvi | General Tech Discussion | 39 | July 16th, 2004 06:55 PM | | sy-k7vem pro | richardking57 | Technical Support | 2 | February 19th, 2004 07:47 AM | | Missing modem in XP Home | bill1971 | Applications and Operating Systems | 8 | July 15th, 2003 09:28 AM | | Cpu temps!! | joker_927 | Processors, Memory, and Overclocking | 14 | January 27th, 2003 03:08 PM | | FA312 on Server | chrisj48 | Networking and Internet | 5 | February 21st, 2002 12:42 AM | |
