using a laptop as monitor
Currently Active Users: 1363
Discussions: 200,930, Posts: 2,379,152, Members: 246,296
Old August 22nd, 2004, 11:53 PM   Digg it!   #1 (permalink)
Question
can i use a laptop as monitor? i want to use an external cpu as my cpu not the cpu of the laptop. is this possible? if so, how can i interconnect things?
corics15 is offline   Reply With Quote
Old August 23rd, 2004, 12:00 AM     #2 (permalink)
Full Time WoW Addict
nwo75200's Avatar
Send a message via MSN to nwo75200
I highly doubt that its possible, I thought about doing it before and I didn't think of a reasonable solution.
nwo75200 is offline   Reply With Quote
Old August 23rd, 2004, 12:03 AM     #3 (permalink)
Perfetc Member
VHockey86's Avatar
You need video-in capabilties on the laptop.... which none of them really do.
you could buy a USB Video capture card, then run an s-video cable from the TV-out of your desktop graphics card, then display the s-video stream on the laptop using the video capture card software....
It could be done, but by the time you buy what you need for a halfass solution, your already halfway to 2/3 to buying a CRt monitor.
VHockey86 is offline   Reply With Quote
Old August 23rd, 2004, 12:06 AM     #4 (permalink)
nwo75200's Avatar
Yea, the cheapest CRT i belive is about 70-80 bucks on newegg
and there's no hassle with the tv tuner and all that *****
Old August 23rd, 2004, 12:08 AM     #5 (permalink)
Onii-san
Bizkitkid2001's Avatar
The reason he may be wanting to use a latop as a monitor might be because of space issues. A laptop takes up less space than a CRT.
Bizkitkid2001 is offline   Reply With Quote
Old August 23rd, 2004, 12:23 AM     #6 (permalink)
thanks for all the info, in the first place i think it's not really possible...
Old September 12th, 2004, 11:33 PM     #7 (permalink)
Thumbs up
www.maxivista.com
It is as easy as 1-2-3: http://www.maxivista.com does exactly what you are looking for.
Devily
devily is offline   Reply With Quote
Old September 12th, 2004, 11:48 PM     #8 (permalink)
the *Voice* in your Head
PresterJohn's Avatar
yes, maxivista will indeed allow you to use the laptop display (you need a nic on the laptop also and windows installed)
i've used maxivista...be warned that it's a little quirky. the software still has some rough edges that need to be worked out.
Old September 13th, 2004, 06:34 AM     #9 (permalink)
You may try http://www.maxivista.com which allows you to use a laptop monitor as a dual monitor of any other PC. Additionally, referring to their FAQ it also allows to mirror a monitor content to another PC.
Devily
Old September 13th, 2004, 06:40 AM     #10 (permalink)
Wink
I would wonder what quirks you mean? Just look at the video they provide on their website:
http://www.maxivista.com/videos/mv_performance.wmv
Simply awesome.
May be that just your system is a bit quirky configurated?
Devily
External monitor for laptop Marcus147 Graphics Cards and Displays 5 September 13th, 2004 06:43 AM
Laptop foodbiz Graphics Cards and Displays 1 June 20th, 2004 01:43 PM
KVM Switch question CyberGhost General Tech Discussion 8 June 16th, 2004 03:48 PM
Odd Question... edwelly General Tech Discussion 10 January 9th, 2004 12:40 AM
Need help with S-Video Effo Graphics Cards and Displays 10 November 7th, 2002 07:49 AM
Is It Just Me? (2869)
Obama the Muslim (14)
favorit (1)
Regular Build (3)
Fire in DVD (2)
Have you switched yet? (84)
Optical Audio A-B Switch (1)
Virus Doctor Popup? (1)
