Help identifying a spyware
Currently Active Users: 2043
Discussions: 200,512, Posts: 2,374,423, Members: 245,836
Old August 26th, 2004, 05:57 PM   Digg it!   #1 (permalink)
I know for sure this problem is caused by a spyware. The sympton is if you put your mouse cursor over the taskbar you get a hourglass, and in general the system is sluggish. I know this is caused by a spyware because by removing bunch of spyware I was able to fix the problem on 2 PCs. I wasn't able to remove one spyware at a time to find out the culprit simply because spyware removal is pain in the butt if done one at a time So which spyware causes this?
Ebisoba is offline   Reply With Quote
Old August 26th, 2004, 06:07 PM     #2 (permalink)
ska7ing away.....
doddsy's Avatar
could be any one of a whole buch of nasties causin your symptoms.
http://www.techimo.com/forum/t48012.html
some useful spyware removal stuff here.
doddsy is offline   Reply With Quote
Old August 26th, 2004, 06:13 PM     #3 (permalink)
This spyware causes a specific problem. The mouse cursor is fine if you click on Desktop items, but once you move the cursor over to the task bar you get a hourglass, and you can't click on anything on the task bar including the Start button. Pressing the Windows key on the keyboard doesn't bring up the Start menu either. I've never seen this behavior before. Saw it for the first time couple of weeks ago. Wondering if it's a single spyware causing the problem or a combination of different ones.
Old August 26th, 2004, 06:19 PM     #4 (permalink)
ska7ing away.....
doddsy's Avatar
it's hard to know. U could run hijack this and maybe find some info in the log from that. or have a look for odd processes in task manager.
my advice would be to get adaware se
http://www.lavasoft.de/support/download/
and spybot 1.3
http://www.safer-networking.org/en/index.html
update both and run scans.
see if that helps.
then get a good firewall and be careful where u surf and what u download (free stuff)
Old August 26th, 2004, 11:08 PM     #5 (permalink)
CMP 2003's Avatar
Ive seen things like this before, I cant tell you for certain its spyware, becuase there is no way i can be absolutely sure. In my previous expierences it has been spyware.
system resources get used up, and for some reason it seems as if the windows shell just freezes up.
AMD A64 3200+ (Venice)@2.2
MSI K8N Neo2 Plat.
Corsair 1GB ddr400 @ 2-3-3-8
eVGA 6800 128mb AGP
WD 80 gb IDE
MGE 500w PSU
MGE Titanium ATX Case
CMP 2003 is offline   Reply With Quote
Driver problem bigfeta Technical Support 11 June 20th, 2004 06:46 PM
Help me get my work pc up to speed camaro General Tech Discussion 16 February 25th, 2004 10:21 AM
Figuring out the entity relationships Tekk Webmastering and Programming 12 October 19th, 2003 01:37 AM
Help, I need help..really bad couch potato Networking and Internet 42 January 11th, 2003 01:30 AM
New machine RAID set up Thumper12 Storage Related 23 November 25th, 2002 07:25 PM
Is It Just Me? (1637)
windows 7 retail and rtm (5)
Review My Build (6)
Assosiations (21498)
My 1st pc build (40)
Aero in Vista (7)
How to Ship a PC (16)
How to put DVD and video on the Sony .. (0)
Powe Director v8 (0)
Review My Build (6)
2009 Build (4)
hard drive problem (2)
Hard Drive test program (2)
