Computer problem
Currently Active Users: 1720
Discussions: 200,933, Posts: 2,379,193, Members: 246,298
Old September 2nd, 2004, 10:05 PM   Digg it!   #1 (permalink)
Computer problem
question about a win ME machine, about 3 yrs old; hard drive 21 gig with only 400 mb free;-running very slow-
removed lots spyware ;
now a worse problem:
when restart, it hangs at the win me screen, and if you hit escape, it says something to the effect of- windows is updating system configuration files, this may take several minutes, please wait-;but it doesn't advance from that point even after 10-15 minutes and just hangs;
one time after computer was off for 3 hours or so it did after a few mnutes get through this sequence and loaded normally to windows;but again after a restart it repeated the sequence and hangs at win me welcome screen, hit escape and see same message asking you to wait for updating system configuration files -but just hangs up and wont proceed past this point;tried to load to safe mode and same problem.
appreciate any thoughts
rak147 is offline   Reply With Quote
Old September 2nd, 2004, 10:11 PM     #2 (permalink)
Dax_Brandy's Avatar
Send a message via Yahoo to Dax_Brandy
maybe you need to delete some unnecessary files. imo.
Dax_Brandy is offline   Reply With Quote
Old September 2nd, 2004, 11:04 PM     #3 (permalink)
I'm not too sure about your specific problem, but you REALLY need to update that OS. Don't even think twice about it. Just upgrade it. My pref is Win 2k, but XP is not bad at all. Also, a bigger hard drive wouldn't hurt. Like dax basically said, you need more space (relates to the speed). Hope this helped...
Alrededor is offline   Reply With Quote
Old September 3rd, 2004, 04:02 AM     #4 (permalink)
Dax_Brandy's Avatar
good suggestion alrededor.
an OS upgrade is sure needed. you may search for some threads here regarding what the other users say about Win ME. shift to 2K of XP!
Old September 3rd, 2004, 04:20 AM     #5 (permalink)
ME upgrade
I held off here, because I thought "change your OS" would sound discouraging. But the other contributors have beat me to it, lol.
Maybe we need to know your system spec first.
Cpu, ram, Vga chip & ram, HDD size, etc.
My number one pet hate is WinME, but my number two is the customer who brings in their 233mmx with their next door neighbours XP loaded & ask "how do I make it go faster?" answer: "Remove XP!" (OK. Slightly extreme example- only saw that one three times per week).
I'm amazed how many POS ME machines have been turned into sweet running little PCs by going BACK to Win98SE. In fact, i refer to ME as a downgrade from 98SE, or "the half-finished OS"
Ultimately, there's a perfect OS for every spec of machine. Give us a hint......
Valtelino is offline   Reply With Quote
Old September 3rd, 2004, 05:29 AM     #6 (permalink)
(AKA) Nakamura
sweeper2's Avatar
"hard drive 21 gig with only 400 mb free;-running very slow-
removed lots spyware ;".......
Sounds like maybe when removing the "spyware" you might have removed certain files that win ME needs... also only having 400 MB free ....clean up the HD or add some things to anther HD....
maybe if you don't want to "update" your OS, you might want to run a repair on your system first to see if that might work...not familiar with win ME, but heard alot of bad things about it....
P4 3.0ghz , P4M900-M4 , 450 psu , Sapphire HD 3850 512mb with an Accelero S1 cooler , 2gig pc5300 ddr2, 80gig Deskstar , 16x dvd-rw
Old September 3rd, 2004, 05:51 AM     #7 (permalink)
Angry
Computer Problem
Every time i shutdown my PC i get the "BLUE-SCREEN-OF -DEATH" just about 2 split-seconds before it turns off
I have freed-up about 6-gig but it still happens (but not as often)
PLEASE HELP ! ! !
ANY SUGESTIONS WELCOME ! ! !
-Butcher
Butcher. is offline   Reply With Quote
Old September 3rd, 2004, 05:59 AM     #8 (permalink)
muarrif's Avatar
Send a message via MSN to muarrif Send a message via Yahoo to muarrif Send a message via Skype™ to muarrif
Arrow
Upgrade operating system
I think you should upgrade to Xp or if your specs do not allow then at revert to Windows 2000 its more stable than the ME.
I have a PC at the moment that I am fixing for a friend and it had problems loading Windows ME also and once loaded it was very slow. It is a Dell make so I have upgraded him to XP and a new drive. All working fine.
You don't really want ME on your machine trust me.
Just get XP home eddition or win 2000
muarrif is offline   Reply With Quote
Old September 3rd, 2004, 06:16 AM     #9 (permalink)
Lightbulb
Sugestion for OS
I agree, Win ME sucks ASS coz it is so un-stable it crashes my friend's PC (witch is vrey fast)
I would rather XP PRO i use that at the moment and i am impressed, alot
-Butcher
Old September 3rd, 2004, 06:38 AM     #10 (permalink)
Exclamation
Please help ! ! !
How do you change your pic on the left-hand side of your post?
PLEASE HELP! ! !
-Butcher
XP Pro and Win 98 Peer To Peer Network Saoude Networking and Internet 20 May 4th, 2005 12:49 PM
ntdll.dll/virtual memory error? realdramaqueen Technical Support 3 September 3rd, 2004 08:42 AM
Diskeeper starting and locking up computer Bizkitkid2001 Technical Support 1 May 23rd, 2004 03:06 PM
Secure Web page login problems with IE hoezeel Networking and Internet 13 April 6th, 2004 09:56 PM
My memory went from 30GB to 1.99GB Squall006 Technical Support 24 December 3rd, 2002 07:38 PM
Is It Just Me? (2886)
Wireless Televisions. (5)
Obama the Muslim (14)
favorit (1)
Regular Build (3)
Fire in DVD (2)
Have you switched yet? (84)
Optical Audio A-B Switch (1)
