Problems with SATA hard drive
Currently Active Users: 2080
Discussions: 200,973, Posts: 2,379,782, Members: 246,336
Old September 3rd, 2004, 12:12 PM   Digg it!   #1 (permalink)
Unhappy
A friend of mine has recently assembled a system to spec. But there is a problem with his hard drive...
Caviar Hard Disk Drive Se 40gb Sata150 7200rpm 8mb
When he powers up, the bios recognises it, but when he tries to install Windows XP pro, it says theres no hard disk.
any suggestions?
any other details needed please ask
Tech0rz is offline   Reply With Quote
Old September 3rd, 2004, 12:15 PM     #2 (permalink)
ska7ing away.....
doddsy's Avatar
u need a sata raid controller installed from a floppy during setup.
wots your mobo?
doddsy is offline   Reply With Quote
Old September 3rd, 2004, 12:16 PM     #3 (permalink)
Jarhed7276's Avatar
You need to install the SATA drivers. When first loading Windows it will ask if you have SCSI or other drivers to install. If yes press F6. Press F6 then it will load a little more Windows then it will ask you to insert the floppy with the SATA drivers. Insert the disk and press OK.
Jarhed7276 is offline   Reply With Quote
Old September 3rd, 2004, 12:25 PM     #4 (permalink)
asdf
his mobo is
gigabyte ga-k8vt800 pro
and Jarhed he can't load windows because it isn't installed. The mobo didn't come with any drivers apperently.
so the solution is RAID Controller?
Old September 3rd, 2004, 12:27 PM     #5 (permalink)
The Real Bingo's Avatar
Well, the mobo hopefully supports SATA drives. If it does, it would normally come with SATA drivers on a floppy.
The Real Bingo is online now   Reply With Quote
Old September 3rd, 2004, 12:30 PM     #6 (permalink)
asdf
ok i've just been informed that he did get a cd witth it...ARGH...so then he has the drivers...how can he install the drivers ? without having windows
Old September 3rd, 2004, 12:34 PM     #7 (permalink)
ska7ing away.....
doddsy's Avatar
if he has the mobo cd theres probably an sata controller on it that u can extract to a floppy.
then at the very beginning of xp pro setup...........u hit F6 when prompted.
then stuff the floppy in the drive when prompted.
done.
i'll have a look for that controller in case u can't find it on the cd
Old September 3rd, 2004, 12:34 PM     #8 (permalink)
As said, when Windows' setup asks to hit F6, do so (hit it a few times to be sure), and insert the drivers. Windows, then, should install normally.
Old September 3rd, 2004, 12:37 PM     #9 (permalink)
ska7ing away.....
doddsy's Avatar
http://www.viaarena.com/?PageID=310
f6 driver and instructions.....................
Old September 3rd, 2004, 12:38 PM     #10 (permalink)
Jarhed7276's Avatar
That motherboard supports SATA. He has to start the windows install process. Then at the beginning of the install Windows will ask if there are SCSI or other drivers to install. Press F6 and a little later it will ask for a floppy with the SATA drivers on it. Insert the floppy and press ok. This will load the SATA drivers and then Windows will recognize the SATA drive. The SATA drivers should be on the cd. Look for them in a folder, maybe called floppy or SATA drivers, and put them on a floppy.
SATA Hard Drive! JaGeR- Technical Support 3 May 17th, 2004 06:59 AM
SATA Hard drive hello23518 Motherboards 1 May 2nd, 2004 11:14 PM
ASUS SATA setup after windows?? PonzSpyder Motherboards 2 January 27th, 2004 12:25 PM
P4 2.8C and Serial ATA hard drives batmeat Processors, Memory, and Overclocking 4 January 3rd, 2004 02:27 PM
Installing SATA on a P4PE motherboard? Gird Motherboards 1 October 12th, 2003 01:55 AM
Charges against non-tippers dropped.. (8)
Is It Just Me? (3059)
The disrespect of Obama by Russian .. (48)
Delete an OS (16)
Nvidia GTX 260 problem (8)
Point and Shoot Camera Suggestions. (7)
Internet Lost (5)
Delete an OS (16)
cell phone won't work (0)
Can't open Word (12)
Open With ..... Win7 (3)
Internet Lost (5)
virus blocking exe. files (1)
Print spooler problem (16)
