September 9th, 2004, 08:26 PM #1Member
- Nov 2003
- 128
system boots in safe not normal mode
OK how and wear do you start when system boots in safe mode but not normal mode its window xp home its on older e machine I get one beep when start as normal .
how do you test something making this not boot in normal it comes on then sites there and you get nothing how do you repair your start boot up thanks oh be as specific as possible thanks
September 9th, 2004, 08:35 PM #2Ultimate Member
- Oct 2001
- 10,821
ok..was it working fine before and now just stopped working??
if so..one thing you can do is boot into safe mode..then go to system restore and restore it back to before the problem started
go to programs/accesories/system tools/restore"Even a fool is thought to be wise if he is silent"
September 9th, 2004, 08:51 PM #3Member
- Nov 2003
- 128
I restored it back a month ago no change and cant seem to run chkdsk either but works great in safe mode this is weired.
September 9th, 2004, 09:26 PM #4Ultimate Member
- Oct 2001
- 10,821
then try this....
boot to the xp cd
1st screen hit enter
2nd screen hit f8 for license agreement
3rd screen hit (R) for repair
this is known as a "repair install"...usually fixes most problems and you wont lose any data etc"Even a fool is thought to be wise if he is silent"
September 9th, 2004, 10:09 PM #5Member
- Nov 2003
- 128
ok how do i find the password as this was set up when i bought it from e machines
September 9th, 2004, 10:40 PM #6
I think the CD Key should be on a label on your CD cover or manual.
September 9th, 2004, 10:42 PM #7Ultimate Member
- Oct 2001
- 10,821
password? or product key?
September 9th, 2004, 10:48 PM #8Member
- Sep 2004
- 71
system specs would help...also, if the above help doesn't do it for you, then what did you do between when it was fine and when it stopped working. What mobo do you have? I've had personal experience with a certain mobo, and while this probably isn't your problem, it'd be a good thing to eliminate so you don't go on a wild goose chase for info...
September 10th, 2004, 12:31 AM #9Member
- Nov 2003
- 128
you ask a bunch of questions I cant answere all i know is this windows xp home e machine model number W4885 have regirastion key for windows xp but was installed before i bought it now i am trying to repair it some how it will work fine in safe but not normal so thought about doing system repair but has some kind password and have no idea as I didnt install this windows it was installed whne i bought it get it !!!!!!!!!!!!!!!!!!!!
system works fine in safe mode but why cant it boot up normally is there a way to repair just the boot system
oh once again I said pasword in recovery mode ( PASSWORD ) I DON't know
September 10th, 2004, 12:37 AM #10Ultimate Member
- Oct 2001
- 10,821
is it a bios password?
if it is a bios pasword there should be a cmos reset jumper next to the battery...you move it over to the "reset" position for a few seconds..then move it back
not sure of any other kind of password.....
any way you can call the place where you bought it?
tell us EXACTLY where you are encountering the password..is it after it is booting to the cd?"Even a fool is thought to be wise if he is silent"
September 10th, 2004, 12:48 AM #11Member
- Nov 2003
- 128
ZI bought it at best buy few years ago , bets me it bios i dont think so because I can enter bios set up i am talking about windows password i guess
September 10th, 2004, 03:41 AM #12Member
- Aug 2004
- Location
- Brisneyland Aust
- 210
Last time I had "Safemode every boot", someone had ticked something in MSConfig on the boot.ini file. Can't remember exactly. It's a long time ago (using W2k ATM) "Safeboot" ?? Something like that.
Anyway, it seemed to be designed to default to safe mode every boot, so you could remove virii, etc.Last edited by Valtelino; September 10th, 2004 at 03:53 AM.
September 10th, 2004, 11:33 AM #13Member
- Nov 2003
- 128
I can boot up in safe mode networking , get online everything but boot normally tried to do system repair but ask's for adminstartor password and dont now what it is as they set it up and noone I been able to talk to nows either .
September 10th, 2004, 11:36 AM #14Ultimate Member
- Oct 2001
- 10,821
hmm..seems like a case where you will have to crack that password, lol
September 10th, 2004, 11:40 AM #15
Sometimes when things get "reset" it asks for a password just to confirm that there *isn't* a password. Have you tried getting to that point, then just pressing "OK" or Enter. Just leave it blank. If it got reset, it'll go.
September 10th, 2004, 12:00 PM #16
You are either hanging on an app that can't start or hardware that is being improperly configured when you attempt normal boot - at least that is how I would read your symptoms.
Did you install any software or make any hardware changes before this problem started?
You might try running msconfig from safe mode (in the run command). From there you could look at items in the startup tab to see if there are any "foreigners". Another tool you might download and install is regsupreme. Run it and let it fix the errors it finds.
Failing any progress, I would start on hardware issues by first disabling the network card and then try rebooting normally.
You will need attempt to isolate this one issue or possibility at a time and continue that effort until you have isolated a prime suspect.WHUT?
Cannot Update My Windows XP
By MCPx2 in forum Applications and Operating SystemsReplies: 16Last Post: July 3rd, 2011, 03:32 PM -
98SE - Refuses to boot after gaming
By Ruler2112 in forum Technical SupportReplies: 5Last Post: February 2nd, 2004, 05:34 PM -
safe mode
By brianl0202 in forum Technical SupportReplies: 2Last Post: September 23rd, 2003, 05:28 PM -
System Crashes
By eastfield in forum Applications and Operating SystemsReplies: 5Last Post: May 29th, 2003, 01:24 PM
Obviously, you are not interested in the time line of the AP story.
AP Story - Dick Morris: Obama did...
