Join TechIMO for Free!
Topic: I have been trying to set up my system for 10 hours now all the wires are in place as far as I can tell yet when I try to power on nothing happens. The green light on the motherboard is on however. The case is a dynapow...
Currently Active Users: 1413
Discussions: 184,690, Posts: 2,205,378, Members: 227,399
Old September 11th, 2004, 12:35 AM   Digg it!   #1 (permalink)
Please Help me! My case power switch won't work
I have been trying to set up my system for 10 hours now all the wires are in place as far as I can tell yet when I try to power on nothing happens. The green light on the motherboard is on however. The case is a dynapower 86b2 with a SOYO dragon ultra platnum and a AMD XP 3100. Please help me !!!!!
Rivka is offline   Reply With Quote
Old September 11th, 2004, 12:40 AM     #2 (permalink)
the *Voice* in your Head
PresterJohn's Avatar
assuming you've got everything connected properly (and that's not something we can readily tell you)...the only way you'll be able to trouble-shoot this is to use another socket A system and start swapping parts one by one.
i'd start w/the power supply since that involves the least amount of work and you might be that '1-in-a-500' that has a bad PS.
good luck.
ps. try removing the mobo from the case and place on a piece of cardboard to see if you don't have a short somewhere.
Old September 11th, 2004, 12:50 AM     #3 (permalink)
I put in a new power supply ( Antec 430 Watt ATX 12v ) tested that it works but still the system does nothing when the power switch is pressed
Old September 11th, 2004, 12:51 AM     #4 (permalink)
unfortunately all my other systems are 478
Old September 11th, 2004, 12:51 AM     #5 (permalink)
how can I tell if there is a short on the MOBO?
Old September 11th, 2004, 12:52 AM     #6 (permalink)
Welcome to the forum!
we have had many threads on this...because it is fairly common....and there are many possibilities
could be
power switch not hooked up to right pins on motherboard..double and TRIPLE check that
some boards/vid cards need that extra 4 pins connector for the aux12v from the power supply....so check for that
make sure the cpu fan is plugged into the right fan pins...some boards wont boot if they dont sense that cpu fan there
lots of times what happens is that the motherboard is shorting out or slightly touching the case somewhere....to find out what you do is take the board back out of the case and try booting it outside of the case...what you do is strip out all the extra cards like nics/sound cards/modems etc....get it down to just cpu/heatsink..one stick of ram..vid card......take th emotherboard out of the case and set it on the motherboard box on the antistatic packaging......
try booting it like that and see what happens.....of course the case switches wont be pluged in cuz the wires arent long enough..so what you do is carefully take a flatblade screwdriver (or hard drive jumper) and short the two pins together where the power switch WAS...just short them briefly and the board should start
of course other possibilities are "dead cpu" or maybe something was damaged by static etc
also you can check the cmos clear jumper.....right beside the battery on the mboard should be a little jumper....usually they come set to the "normal" position....but some come set on the "clear" or "reset" position and you have to move it over to the 'normal" position to boot
or if it is on the "normal" position now you can also try resetting the bios by moving that jumper to the 'clear" position for a few seconds...then move it back
JP
Old September 11th, 2004, 12:56 AM     #7 (permalink)
The thing that makes this difficult is that the case came with no manual and a plethora of wires for the front switches and lights
Old September 11th, 2004, 01:01 AM     #8 (permalink)
how can I tell if the mother board requires the extra 4 pin power wires?
Old September 11th, 2004, 01:02 AM     #9 (permalink)
Kawaru wa yo!
Whir's Avatar
Rivka, please stop posting this problem in other threads. If you have any questions about how to use TechIMO, please read our FAQs and policies.
Old September 11th, 2004, 01:02 AM     #10 (permalink)
then it might well be just a wrongly swapped connector to the mobo.
you should *seriously* think about swapping that mobo to another case that has clearly marked 'power on' (etc) cables. otherwise, all your troubleshooting is all just shooting in the dark.
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Computer Wont Turn On lablkilz699 Technical Support 7 September 9th, 2004 11:28 PM
Shuts down and stays dead scarecrow1 Technical Support 6 May 8th, 2004 12:12 PM
Smoked another PSU....Grrrrrr!!!!!!!!!!!! Dooin' it General Tech Discussion 43 January 3rd, 2004 01:23 AM
Ack my power button isn't working! RE_Templer General Tech Discussion 10 December 11th, 2003 02:56 PM
Just built a new computer, no power. *about to go postal* luckyquark Technical Support 3 September 7th, 2002 02:17 PM
Is It Just Me? (13813)
Weirdest case ever... (10)
Farrakhan on Obama: 'The Messiah is.. (10)
Custom external storage build, need.. (8)
so u cant crossfire with a HD 4850 .. (9)
John McFlIpFlOpPeR - for Bingo =) (50)
Building my first desktop (9)
NOOB VB.Net questions (5)
Graphics Card for COD 4 (5)
wholesale cheap discount nike j.. (0)
6TB+ RAID solution? (5)
RAID 5 Configuration (2)
dvd portable player (4)
*********** /company of heroes.. (0)
*********** /need for speed un.. (0)
***********/NWN 2 cd key (0)
Unable to start the Bluetooth s.. (1)
Custom external storage build, .. (8)
Drive won't partition? (3)
