Volume issue when playing DVDs
Currently Active Users: 1480
Discussions: 200,931, Posts: 2,379,162, Members: 246,297
Old October 8th, 2004, 08:26 AM   Digg it!   #1 (permalink)
Send a message via MSN to whip_cracker
Angry
G,day guys,
I seem to be havinga problem when I'm playing my movies on the puter and stuff, I have a DVD burner of some sort, being the DW-U18A Liteon drive. The volume bloody GOES DOWN ay?? and it's really starting to *deleted me off...
Does anyone have any advice to see if it's a easy fix or whatever??
Thanx guys in advance!!
Watch the language please
GroundZero3
whip_cracker is offline   Reply With Quote
Old October 8th, 2004, 08:34 AM     #2 (permalink)
Retired mostly.
You might want to edit certain words from your post.
Does the volume gradually drop, or it's low from the beginning?
What program do you use?
Old October 8th, 2004, 08:38 AM     #3 (permalink)
Drops all of a sudden... then somehow creeps back up... it's intermittent... does it on 2 programs that I use. I'm using Intervideo WinDVD 5. It's irritating because I like playing ACDC loud and stuff :P
Old October 8th, 2004, 08:52 AM     #4 (permalink)
Retired mostly.
Hehe.
I was like wth when I used windvd5 and suddenly my middlechannel (in DD mode) lost all sound making the movie insta mute-film.
Turned out to be that I had the cable connected loosely, and it lost contact every now and then.
So, it could be bad cabling, or it could be audio filter you're using (either windvd's audio filter or perhaps ac3).
Try an alternate program, preferrably one that has internal codecs like vlc (www.videolan.org)
Old October 8th, 2004, 04:36 PM     #5 (permalink)
what is this perticular cd and dvd like when playing through a normal stand alon dvd/cd player, I always find it better using a dvdrom to view dvd and cd media, keep the burner for 1 purpose only burning diosc's not playingthem, what type of hoookup to your sound system, analog/co-ax digital/optical digital..
to rectify any problem you got update audio for our soundcard, playing music continuesly loud will shorten the life of the speakers, if you start hearing whistling & pops during playback it time to get speakers replaced.....
this statement refers to any problem you may have in the future...
redacidman is offline   Reply With Quote
Old October 10th, 2004, 11:52 PM     #6 (permalink)
Nah, sound system's fine... I can play any mp3s fine... I have 5.1 Surround. I play my music high, but I got speakers that can handle it (100w RMS each) so yeah. It's a normal analogue input and the drivers are fully updated. I have used Power DVD before and had the same problem... I'm not gonna bother buyin a DVD ROM as the last one shit itself, and when I play the DVDs on the DVD player in the house, there's no problem. I guess it could be codecs, but I'm not sure where the hell to find em.
Oh well... I guess I'll figure it out soon enough. I can ask the guys here @ work, I'm a Network Support Officer, so there's bound to be some kinda info around here :P
Old October 11th, 2004, 05:57 PM     #7 (permalink)
there maybe a fault with windvd5 check thier site for updates.. if problems persist...
Old October 12th, 2004, 12:35 AM     #8 (permalink)
Ok, I'll have a squizz at it when I get back home, I'm @ work at the moment.
Audio Crackling Vertiginous Multimedia and Audio 3 November 12th, 2003 11:42 AM
so asus tech support says send in my mobo.... sao95 Technical Support 7 October 9th, 2003 12:35 AM
What % of DVD Movies can't be ripped? patyoda Multimedia and Audio 13 August 16th, 2003 03:42 PM
audio problems playing CD music dmoura Technical Support 3 April 23rd, 2003 12:49 AM
Is my DVD-ROM dead? Ritalin Kid Technical Support 8 December 19th, 2001 03:52 PM
Is It Just Me? (2874)
Obama the Muslim (14)
Wireless Televisions. (0)
favorit (1)
Regular Build (3)
Fire in DVD (2)
Have you switched yet? (84)
Optical Audio A-B Switch (1)
