I've been searching around for a driver for this device but can't seem to locate it. I'm not quite sure if it even exists. Belkin only has the Sentry Bulldog monitoring software under their support downloads and the manual for my model (F6C625-SER) talks about a USB hookup even though the unit is a Serial one. Everytime I load up Windows 2000 it re-asks me to install the driver. I'm not sure if it's okay to disable the device so it stops getting detected. The supplied software seems to communicate with the device fine even though no driver is present.
Anyone have any advice or info for me...
