Power Supply Info
Currently Active Users: 2383
Discussions: 200,942, Posts: 2,379,313, Members: 246,305
Old July 10th, 2005, 02:06 PM     #91 (permalink)
Exclamation
hi, i have a pcv-rx650, a sony when. and i need a psu that will fit. sony psu are such an odd dimension, people say the micro atx will fit? can you guys give me recommendations for one, i need to get my 6600GT card working cause i dont like the stardard psu. please help me find a psu.
blastypants is offline   Reply With Quote
Old July 11th, 2005, 02:35 AM     #92 (permalink)
The Macedonian Member
njolakoski's Avatar
Send a message via AIM to njolakoski Send a message via MSN to njolakoski Send a message via Yahoo to njolakoski
HEC Orion 585W ATX- http://www.directron.com/hp585d.html
Is that a good PSU?
njolakoski is offline   Reply With Quote
Old July 11th, 2005, 10:13 AM     #93 (permalink)
njolakoski's Avatar
Bump, Id like to know about the PSU above ^^^^
Old July 11th, 2005, 08:55 PM     #94 (permalink)
Cool
dzee is offline   Reply With Quote
Old July 12th, 2005, 03:57 PM     #95 (permalink)
Send a message via AIM to zskillz
Perhaps I missed it in this thread, or maybe it hasn't come up yet...
I'm curious what rails the new PCI express equipment runs on... does x1, x4, x16 all run on the +12V? The power calculator provided in the first post doesn't seem to help answer this question either.
thanks,
-Z
zskillz is offline   Reply With Quote
Old July 12th, 2005, 05:53 PM     #96 (permalink)
I need help looking for a new PSU. I am current running on the PSU that came with my case, because the one I bought overheated. The purpose of my computer liek most people is gaming. In addition to my comp specs you see in my sig i need it to have sufficient amount of power to run 4 case fans. The fans I am using are the MASSCOOL FD08025S1M4 80mm Sleeve Cooling Fan - Retail One more thing., it will also need to be able to support my 2nd XFX 6600GT 128MB PCI-E when I decide to purchase it.
LD50 is offline   Reply With Quote
Old July 12th, 2005, 10:04 PM     #97 (permalink)
Training for Bankai
JPMiller's Avatar
There are VERY few certified SLI PSU's at this point...
You definitely want dual +12V and 400W or better...
Old July 12th, 2005, 10:14 PM     #98 (permalink)
Megalomaniacal
SoloCamo's Avatar
Send a message via AIM to SoloCamo
atleast 400w for SLI
SoloCamo is offline   Reply With Quote
Old July 12th, 2005, 11:43 PM     #99 (permalink)
ATI 4850 FTW!
#43 fan's Avatar
in other words, buy the best you can get.
http://www.ubuntu.com
Old July 13th, 2005, 01:28 AM     #100 (permalink)
If I get a duel 12V do I need to connect both of them? cause according to my mobo I can only connect 1 12V. If I only connect 1 of the 12V does it mean I only get half of the Ams? or what? Im not really familar with duel 12V PSU's so I would not really know. If someone could please explain it to me.
power supply indi Technical Support 34 April 1st, 2009 03:19 PM
"System failed CPU test"?/CPU multiplier TuEKiD Processors, Memory, and Overclocking 8 May 6th, 2006 12:13 AM
Power Supply issues BadboyAl General Tech Discussion 9 July 22nd, 2003 12:31 PM
asus A7N8x system crashing stamenkd Technical Support 14 July 13th, 2003 10:02 PM
Help build an AMD for under $500 Mr. NoOne Technical Support 26 May 25th, 2003 04:05 AM
The disrespect of Obama by Russian .. (10)
Making Health Care Worse (151)
Is It Just Me? (2918)
Wireless Televisions. (11)
Regular Build (6)
Print spooler problem (15)
Have you switched yet? (86)
Asus P4G8X Mobo (5)
sms storage to PC (0)
Regular Build (6)
Open With ..... Win7 (0)
java code for fibonacci (1)
Modern Warfare 2 freeze (13)
wireless user (1)
favorit (1)
