July 13th, 2005, 12:50 PM
#101 (permalink)
| Quote: |
Originally Posted by JPMiller There are VERY few certified SLI PSU's at this point...
You definitely want dual +12V and 400W or better... |
I presume this is an answer to my question about the pci express power requirements??
if so, I'd really rather be more specific. I don't need SLI, but when we're calculating what's needed for our PSU, we need to know what components draw how much amperage from what rail. I was hoping someone could answer this for me regarding the typical pci-e device
-Z |
July 13th, 2005, 04:16 PM
#102 (permalink)
Well even single pci-e video uses tons mor ethen any normal pci-e card. Each card will draw what it needs, like agp or pci. After the max of what it can deliver it uses a direct connect to the psu molex. So go by your cards power useage not the bus itself.
R.I.P. TKOP
July 14th, 2005, 09:26 PM
#103 (permalink)
July 15th, 2005, 03:10 AM
#104 (permalink)
The only difference I can see is the fan configuration, my preference is the one 120mm fan, less noise and better cooling from what I can see... |
July 15th, 2005, 06:14 PM
#105 (permalink)
Well someone told me other differences besides the fans. That the 1st link is passive cooling, while the 2nd is active cooling. |
July 16th, 2005, 07:02 PM
#106 (permalink)
| | Megalomaniacal
I heard a lot of pretty good reviews about the TT 420 silent pure power... does it really live up to the hype? because im considering picking one up to replace my now dying 420watt raidmaxx
__________________ -------
July 16th, 2005, 08:50 PM
#107 (permalink)
| Quote: |
Originally Posted by SoloCamo I heard a lot of pretty good reviews about the TT 420 silent pure power... does it really live up to the hype? because im considering picking one up to replace my now dying 420watt raidmaxx | yes.... as far as Im concerned it is the best bang for buck at this time...
-------------------------- Quote: |
Originally Posted by LD50 Well someone told me other differences besides the fans. That the 1st link is passive cooling, while the 2nd is active cooling. | Passive cooling involves HUGE heatsinks that extend out the back of the case and have NO fans... the specs are identical and both have ACTIVE cooling, the only difference is the fan configuration... period...
they probably roll off the exact same assembly line and simply get different housings... |
July 16th, 2005, 09:07 PM
#108 (permalink)
| | Megalomaniacal
I know aspire's aren't exactly the greatest psu's out there, but my brother has one powering his rig (fx-53, x800pro, 2x 1024 ram, 2opticals, 1hdd, 4 fans, floppy)
It's the aspire 500watt http://www.xoxide.com/noname24.html
I heard it was one of the "better" aspires out there,
now what i am most likely going to do is by my bro that TT 420w and replace his aspire with it.
Then take his aspire and put it in my rig which is running less, and weaker components.
The aspire is huge, so it is blocking a blowhole in his case, therefore not allowing him to place a fan in there.
can that particular aspire be trusted enough to run a system with less demanding components?
I'm assuming the TT is a superior psu, but do you think it is worth the hassle of swapping out his psu for the TT? or do you think the aspire will do fine for it? |
July 17th, 2005, 01:25 AM
#109 (permalink)
I would do the swap...
The less draw you have on that Aspire, the less chance of it blowing, the longer it will last and the cleaner the power youll get...
I wouldnt tell someor to buy one, but if its in use and your not having problems with it, putting it in an underpowered tower will at least make the scenario better |
July 17th, 2005, 12:33 PM
#110 (permalink)
| | ATI 4850 FTW!
Even the worst PSU today can run a very low end system with no problems.
In other words, a Pentium 3.  |
