March 23rd, 2008, 03:43 AM
#251 (permalink)
| | Reaper
| http://www.newegg.com/Product/Produc...82E16817814005
Good PSU? My Fortron is on it's death bed, and I'm in the market for something that'll last me a little longer with a few major power hungry upgrades on the way. I like the look, and the specs aren't too bad either. There's a good MIR on it too.
March 23rd, 2008, 12:06 PM
#252 (permalink)
| | SoMuchAnime-SoLittleTime
That looks great.
The mark of the immature man is that he wants to die nobly for a cause, while the mark of a mature man is that he wants to live humbly for one.
March 23rd, 2008, 09:44 PM
#253 (permalink)
I see a new trend ,everyone is getting PSU that are 700w and above .Is this over kill ,how much power do they really need
My computer has a PSU thats about 4yrs a old Antec TPII-550
the antec load is
AMD 64 X2 6400 BLK CPU
ZALMAN CNPS9500 LED heatsink fan
DFI DK 790FX MOBO
Sapphire HD3870 GPU
OCZ Titanium XTC 2X1GB
2 500Gb HDD
2 250Gb HDD
2 DVD Burners
9 slot card reader
floopy reader
8 80mm fans
2 black lights
all on my power supply ,how much more power could SLI or crossfire pull than my system.It's a new build ,but I think my computer is running fine . Is my PSU holding me back, My MOBO can handle 3-way CrossFire . What will I need,a 1000W Psu if I go crossfire.
AMD64X26400BLK/OCZ Titanium XTC 2X1GB /DFI DK 790FX /Sapphire HD3870 /Antec TPII-550/1.5Tb maxtorHDD
March 23rd, 2008, 10:42 PM
#254 (permalink)
3 way crossfire will probably use around 500-700 watts alone (just the 3 cards) with full load. That doesn't quite sound right...but thats what it looks like (though I am quite tired, would not be surprised if I missed something). |
March 23rd, 2008, 11:31 PM
#255 (permalink)
| | ATI 4850 FTW!
Well, the Power Supply may be overkill, but you're guaranteed for power.
I'd say a 1 KW+ PSU may be appropriate. |
April 12th, 2008, 08:19 PM
#256 (permalink)
| I think it's time for a new PSU
specs
DFI DK 790FX MOBO
Sapphire HD3870 GPU
2 500Gb HDD
2 250Gb HDD
2 DVD Burners
9 slot card reader
floopy reader
8 80mm fans
2 black lights
ADDing
SAPPHIRE 100221SR Radeon HD 3870 X2 1GB
going crossfire So I need more power,
I think I have a sell for my AMD 64 X2 6400 BLK CPU for $130,going to replace it with
AMD Phenom 9850 BLACK EDITION 2.5GHz 4 x 512KB L2 Cache 2MB L3 Cache Socket AM2+ 125W Quad-Core Processor - Retail $245
anyway this is what I was looking at for a PSU
FSP Group BoosterX 3 FSP300-1E01 Independent/Supplementary Max. 400W supplementary Power Supply - Retail $90 http://www.newegg.com/product/produc...82E16817104019
HIPER HPU-4M880 ATX12V / EPS12V 880W Power Supply 100 - 240 V UL, CE, CB, TUV, FCC, CSA - Retail $150 http://www.newegg.com/Product/Produc...82E16817128010
SILVERSTONE OP850 ATX 12V 2.2 & EPS12V 850W Power Supply 100 - 240 V CE, cUL, TUV, FCC - Retail $190 http://www.newegg.com/Product/Produc...82E16817256024
FSP Group Everest 900 ATX12V V2.2/EPS V2.91 900W Power Supply 110 - 240V RoHS, UL, CSA, VDE, NEMKO, CNS, CE, CB, FCC - Retail $240 http://www.newegg.com/Product/Produc...82E16817104042
Antec TPQ-850 ATX12V / EPS12V 850W Power Supply 100 - 240 V UL, CUL, FCC, TUV, CE, C-tick, CCC, CB - Retail $200 http://www.newegg.com/Product/Produc...82E16817371009
April 17th, 2008, 09:11 AM
#257 (permalink)
| | ATI 4850 FTW!
Having a Power Supply that was "overkill", such as 1000 watts vs. the needed 400 watts, wouldn't cause damage to the computer, correct (assuming it was designed correctly)? |
April 17th, 2008, 12:04 PM
#258 (permalink)
| | Megalomaniacal
| Quote:
Originally Posted by #43 fan Having a Power Supply that was "overkill", such as 1000 watts vs. the needed 400 watts, wouldn't cause damage to the computer, correct (assuming it was designed correctly)? | No. The computer will only draw as much as it needs.
__________________ ------- |
June 26th, 2008, 06:51 AM
#259 (permalink)
Hi guys, this is my first post here and it looks like a great site for help & advice so I'm hoping someone can help me here. I'm on a tight budget (just lost my job  ) and I need a new PSU for my system which hasn't worked right since day one. Here are my specs:
Intel E6850 CPU with Tuniq Tower 120 HSF
2x1GB OCZ DDR2-800 Memory (1t timing)
DFI Lanparty DK X48 Motherboard
ECS Geforce 8800GTS 320MB PCI-E Video
Antec 900 Case
2x 300GB Maxtor SATA-2 hard Disks
2x 500GB Seagate SATA-2 Hard Disks
Liteon 20 Speed IDE DVD Writer & Pioneer 212 SATA DVD Writer
4 case fans included with case
Enermas Noisetaker 600W SLI PSU
Now I had an ASUS P5n32-E SLI mainboard in that I thought was causing my problems and have changed that for the new DFI and I also changed the RAM not so long back too so that counts those both out. I want to try overclocking, which used to work a little for a while but it's now a struggle to get my system running OK as standard. I am also going to change the Video Card for 2x Radeon 4850 cards when I start back at work again so I am looking for a pretty powerful but well priced PSU.
I noticed that the Hi-Power PSU's are listed in the Good section in the first post of this thread, are these the ones being sold by ebuyer? The one I'm looking at is here on ebuyer and I know some of you will say 1000w is overkill but I want to make sure I've got more than enough handy for any potential upgrades. Does anyone use these PSU's and how do they stack up against the big buys (with big price tags)? |
September 5th, 2008, 11:29 AM
#260 (permalink)
